Thread: Which Amp for my BTL 15?s. Recently got a Fi BTL 15, full y |
New member Username: Bone32
Post Number: 5 Registered: Jun-08
| Posted on Wednesday, July 23, 2008 - 08:47 pm: |
Hey guys, recently got a Fi BTL 15. Wondering which of these 2 amps would power it best or if there is anything else that would be better for $500 or less. Thanks Amp 1 - http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18538 Amp 2 - http://sonicelectronix.com/item_12212_Hifonics+BXi+2608D.html |
Gold Member Username: Insearchofbass
Post Number: 9981 Registered: Jun-04
| Posted on Thursday, July 24, 2008 - 08:46 am: |
I wouldnt even consider the crunch amp way over rated. The hifonics amps are over rated too no where near like the crunch but the hifonics amps are known to have issues from time to time. If i was you Id look for the old orion 2500d there is someone on here selling a used one for 350 shipped. The new orion amps claim a higher rating but are half their rated power in true rms. This is all assuming you have dual 2 ohm voice coils because thats the only way youll get a 1 ohm load. I also hope you have a high output alternator because you have an amp there capable of 225 to 250 amps of draw and thats not counting any other amps you are running or your cars basic electrical needs. heres a link to the guy selling the orion 2500d http://forum.ecoustics.com/bbs/messages/4/503688.html |
Gold Member Username: Ctmike
Ct.
Post Number: 6388 Registered: Feb-06
| Posted on Thursday, July 24, 2008 - 08:58 am: |
maybe an audioque 2200? it's what, $400 shipped? |
Post Number: 9985 Registered: Jun-04
| Posted on Thursday, July 24, 2008 - 09:29 am: |
I thought of that mike but he has full options so I wanted to give him more power but I guess that would be enough. |
Post Number: 6 Registered: Jun-08
| Posted on Thursday, July 24, 2008 - 10:42 am: |
I thought you had to have 4 ohm to wire it down to 1 ohm... i always thought it wasnt possible to do it with a 2 ohm |
Post Number: 9990 Registered: Jun-04
| Posted on Thursday, July 24, 2008 - 10:55 am: |
Dual 4 ohm coils can be wired to 2 ohms or 8 ohms and a dual 2 ohm can be wired to 1 ohm or 4 ohms but fi only makes dual 1 and dual 2 ohm coils and if you got dual 1 ohms you can only wire it to .5 ohms or 2 ohms. And you need buy an amp stable at your final ohm load that produces the power you want. Plus like I said you need the electrical support from your charging to support that kind of power or bad things can happen. Heres a link for wiring options. http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=12 |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5414 Registered: Dec-05
| Posted on Thursday, July 24, 2008 - 07:18 pm: |
talk to kevin holden |
Silver Member Username: Ridinspinnas
Windsor,
Ontario
Post Number: 351 Registered: May-06
| Posted on Sunday, July 27, 2008 - 04:05 pm: |
get a kicker zx2500 somebodys selling one on ssa for around 500 i think |
Silver Member Username: Bumpin_buick
Appleton,
Wisconsin
Post Number: 137 Registered: Apr-07
| Posted on Sunday, July 27, 2008 - 11:10 pm: |
slapmaster on CA.com has a RF T20001bd for like $400. I had a T40001bd on a pair of BTLs in my daily driver a while back, it was really nice for daily. |
