Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Amp for 2 l7
Author Thread: Amp for 2 l7
Username: Mc_9774
hey guys
kinda new here so help me out aight?
aight
so ima put 2 kicker l7 12"s
in my 01 mdx, ported box..
which amp should i use to power it up?
Username: Ctmike
Ct.
Post Number: 6383
budget and the subs' voice coils would help.
Username: 04redmach1
Es DEALER, GA
Post Number: 2200
Have you already bought the sub? If not, you will be better off getting dual 4 ohm coils.
What is your budget for amp?
Kevin
Username: Ridinspinnas
Windsor, Ontario
Post Number: 323
yup, get the dual 4 ohms, so u can wire it down to 1 ohm, and get a hifonics bxi1608d or bxi2008d, unless ur budget is higher
Username: Mc_9774
aight guys
ima be spending about a grand on the whole system..
so.. $250? on the amp..
maybe 300 at most
the speakers is dual 4 ohm coil
Username: Ctmike
Ct.
Post Number: 6386
go with a hifonics since your budget is kinda low. get the bxi2008 like posted above.
Username: 420alldaylong
Post Number: 3755
http://www.audioque.com/aq/AQamps.htm
Username: Mc_9774
ok so let me think this through..
the subs are 750rms each which means
1500rms at 4ohms...
and if i parallel them i would get 2ohms
and more wattage right?
damn.. confusing
thanks ppls for helping
btw
Username: Ctmike
Ct.
Post Number: 6387
get a 1ohm stable amp and wire the pair down to 1ohm.
and this amp:
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19395
Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Amp for 2 l7 [ « Previous ] [ Next » ]
