Home > Message Board > Car Audio > Subwoofers > Archive through July 21, 2008 > Amp/Sub Compatibility Question!!!
Author Thread: Amp/Sub Compatibility Question!!!
Username: 420pimp2
Post Number: 840
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4199
This amp would be great for two type r's correct? And if so i would want the 4-ohm type r's and wire them down to a 1 ohm load on this amp?
Username: Ctmike
Ct.
Post Number: 6365
spend a bit more and get the 1606 (think that's the model #), hifonics' tends to overrate their amps a bit. and yes, you'll want the dual 4ohm subs to wire to a 1ohm load.
Username: 420alldaylong
Post Number: 3736
That Hifonics BXi1206D will work just fine but with shipping cost you will be around $245-$250 price range. So take a look at the AudioQue AQ1200D(1200x1@1ohm $249 shipped).
http://www.audioque.com/aq/AQamps.htm
Username: Hittin1
Lake Charles, La.
United States
Post Number: 797
^^^ agree The hifonics bxi1608 will have trouble putting out what the AQ1200D WILL put out and for cheaper.
Home > Message Board > Car Audio > Subwoofers > Archive through July 21, 2008 > Amp/Sub Compatibility Question!!! [ « Previous ] [ Next » ]
