Thread: Porsche 911 install advice please. |
New member Username: Rollandburn
Post Number: 1 Registered: Jul-08
| Posted on Sunday, July 20, 2008 - 06:04 pm: |
Hi, I wonder if anyone could give me some opinions on an audio install for my 1985 911. Obviously there is limited space, but I'm still going to try to squeeze as much out of it as I can. =] The only gear I have so far is a decent JVC head unit with 3 pre-outs and a Rockford Fosgate Power1000 5-channel amp. The Power1000 is rated as follows... 100w x 4 @ 4ohms 150w x 4 @ 2ohms ...and a 5th channel I'd like to run two 4ohm 10's in parallel to get 600w x 1 @ 2ohms. They will be in a sealed .5cu ft box behind the seats.. similar to http://caraudioinnovations.com/porsche.htm This leaves me with decisions to make concerning components in the doors and rear fill. Stock sizes are 5.25 up front and 4x6 in the rear. 6.5's will fit up front with slight modifications so I'd like to go with that size. The rear I know isn't supposed to blast your head off and am wondering if I should stick with the stock 4x6 in the rear. Once I choose the size do you guys think I should also consider accessing the amps capability of outputting 4x150@2ohms, or do you think the 100x4@4ohms will be sufficient to keep up with the two 10"s. I am open to any and all suggestions. Thanks! ps. I don't want to spend $800 on components....between the front and rear my budget is around $300-$350, and to maximize those dollars I'll be looking on ebay first. Meaning crutchfield etc... is good for research...but if I can get $400 cructhfield components on ebay for $250 why not! I might even settle for super high quality used at the right price. pss. I listen mostly to electronic music (house, drum & bass) and jazz... |
Post Number: 2 Registered: Jul-08
| Posted on Sunday, July 20, 2008 - 08:07 pm: |
my bad... i got the power ratings of the amp wrong. From the book... Rated Power continuous power Front/Rear Channels 50W x 4 @ 4-Ohms RMS 100W x 4 @ 2-Ohms RMS 150W x 4 @ 1-Ohm RMS 200W x 2 @ 4-Ohms Bridged Mono 300 x 2W @ 2-Ohms Bridged Mono Sub Channel 300W x 1 @ 4-Ohms RMS 600W x 1 @ 2-Ohms RMS 800W x 1 @ 1-Ohm RMS 2ohm speakers front/rear looks good in that case~ |
Silver Member Username: Exige
CDT, Audiopulse Dealer
Post Number: 522 Registered: Nov-07
| Posted on Monday, July 21, 2008 - 12:12 am: |
2ohm speakers are very rare. Stick with 4-ohms. RF amps are underrated..you'll get some more power than that Definitely go with the 6.5's as mentioned. Skip rear speakers and keep your stock ones. Does the $800 budget include the subs? or just components? |
Post Number: 3 Registered: Jul-08
| Posted on Monday, July 21, 2008 - 08:54 am: |
Hi, thanks for the response exige....I agree... the amp will definitely put out more than 50x4@4ohms... i just wondered why there would be any reason to NOT use the capabilities of the amp at 2 ohms while I am in purchase mode. The rarity of 2 ohm components won't deter me if is a better choice. The rear fill. Those two rear channels will be sitting idle if i don't use them. I always understood rear fill to be a necessity when attempting to achieve a good sound stage so I think for the minimal amount a pair of 4x6's cost it would be a good idea...even if at a super low volume. Oh yes, the $800 figure was one I didn't want to reach... I was thinking more along the lines of around $300 for the front and rears, and then spend another $250 on two 10's. what do you think? |
Post Number: 541 Registered: Nov-07
| Posted on Tuesday, July 22, 2008 - 06:00 am: |
Sorry I misread regarding the budget. Go with an efficient set of 4 ohms speakers. Just cause your amp can put out more does not mean you HAVE to use that power. Keep your rears stock...trust me. Rear fill typically only throws off your soundstage...especially in a car as small as yours. Have you had a chance to listen to ay speakers yet? Can you give us any references so we can point you in the right direction? |
Post Number: 4 Registered: Jul-08
| Posted on Thursday, July 24, 2008 - 02:02 pm: |
I haven't listened to anything in the stores yet. I get the feeling that because the sound of a speaker is so subjective, depends on the install, the car, etc... that even listening to a set in a shop won't give me a real good idea of what they'll sound like once placed. I've been kinda riding on numbers and price....I figure if the numbers are right and I buy the most expensive ones I can afford, that'll give me the greatest chance of attaining satisfaction. I wish there were places in my town to listen to others setups but there just isn't. Can you tell me what qualifies as 'efficient'? >91db? Thanks for the help |
Bronze Member Username: Fritos2
Post Number: 37 Registered: Apr-08
| Posted on Thursday, July 24, 2008 - 04:53 pm: |
porsche 911 niceeeee |
Post Number: 553 Registered: Nov-07
| Posted on Thursday, July 24, 2008 - 06:23 pm: |
Yes, very nice car lol. Efficiency is subjective. I typically say 89dB and up...but there's no exact amount. Check your PM's by the way. What I would recommend is the 6.5's up front, stock in the rear, and bridge your amp to get more power up front. |
Post Number: 5 Registered: Jul-08
| Posted on Friday, July 25, 2008 - 09:46 am: |
I'd love to check my PM's but apparently I need special glasses or something to see where to access them. The content on this site is good but the interface leaves something to be desired. Thanks everyone. =] |
Gold Member Username: Tatonka
-[Team Audible
Insanity]-
Post Number: 2079 Registered: Mar-07
| Posted on Friday, August 08, 2008 - 10:03 am: |
quote:The content on this site is good but the interface leaves something to be desired.
Tell the admin that and he deletes your thread Anywho, your PMs are sent to your email inbox that you used to register with this site. |
Post Number: 6 Registered: Jul-08
| Posted on Friday, August 08, 2008 - 11:14 am: |
hehe... well I'll always be biased having worked in the web industry for too many years. Thanks for pointing out that the pM's are emails in effect... i did receive yours. =] Just to let everyone know how this has been coming along for me... I bought a new set of MB Quart QSD 216's that I'm going to run up front..... no rear stage at all. And for subs, I bought two MB Quart shallow 10's ... screwed up because I bought DVC instead of SVC. I was hoping to run the sub channel at 2ohms, splitting 600w between the two. Now that the wiring possibilities of two DVC subs forces me into either 1ohm or 4ohm, it looks like I'm going to have to do 1ohm. Luckily, the amp is rated to do 800w @ 1ohm and the subs are 400w each. =] rolland |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 8142 Registered: Jul-06
| Posted on Friday, August 08, 2008 - 04:36 pm: |
Definitely bridge the amp to get more power to the front speakers. But where I REALLY disagree with exige: get rid of the rears, don't leave the stock ones in there. Stock speakers from 1985 are going to sound terrible and will do nothing but screw up the sound of whatever components you decide to put in front. |
Post Number: 630 Registered: Nov-07
| Posted on Monday, August 11, 2008 - 06:09 pm: |
All that I was implying was: do not waste money on purchasing new rears. I'm not meaning he has to actually USE his old ones. But, it's pointless to buy new ones though. (I never actually said to keep the rears hooked up ) His statement: "I always understood rear fill to be a necessity when attempting to achieve a good sound stage so I think for the minimal amount a pair of 4x6's cost it would be a good idea...even if at a super low volume." Reread this comment I stated above: Rear fill typically only throws off your soundstage...especially in a car as small as yours.
Reading too much into it. |
