Home > Message Board > Car Audio > Subwoofers > Archive through July 21, 2008 > RE SX Or MT --------- FI BTL
Author Thread: RE SX Or MT --------- FI BTL
Username: Ote888
Philippines
Post Number: 17
which do you guys think would be better? which will be louder?? here in the Philippines that 2 loud bad sub woofers
are competing but then still complicated for me which would one is louder.. that would hit higher in db's thanks!
Username: Shade
Moxee, Wa
U.S.
Post Number: 691
install dependent....i would choose either the MT or BTL...but the BTL would have to be fully loaded.
Username: Ote888
Philippines
Post Number: 18
does the mt is only for spl purposes? not like btl which you can also play for daily drive?
Username: Shade
Moxee, Wa
U.S.
Post Number: 693
mt can be for daily....i almost bought one for daily.
Username: Kingandsons07
Lincoln, NE TEAM RD
U.S.A
Post Number: 1086
mt daily =]
Username: Tejcurrent
Post Number: 1427
I chose the btl over the mt personaly
Username: Shortysetnies
Rock Vegas, NC
US
Post Number: 2692
I had a friend that ran 2 15" MTs ported, everything was setup right with proper charging and it was the second loudest (154.x) vehicle Ive been in.
He did have a problem with the dust caps getting way too hot, leadin to the coming off but other than that, it slammed
Username: Loc_out
SOCAL
2 RE 15 XXX
Post Number: 2293
It all comes down to install and proper charging sytem. What amp would you be using?
Username: 420alldaylong
Post Number: 3738
With that said^^^^^
Out of those three subs listed I would go with the Fi BTL or RE MT.
Oh yeah RD Audio is putting up good numbers at the comps so you mite want to take a look.
RD Audio.net^^^^^
What amp(s)?
Username: Loc_out
SOCAL
2 RE 15 XXX
Post Number: 2294
it comes down to can you power a MT/BTL/RD
Home > Message Board > Car Audio > Subwoofers > Archive through July 21, 2008 > RE SX Or MT --------- FI BTL [ « Previous ] [ Next » ]
