Home > Message Board > Car Audio > Subwoofers > Archive through July 21, 2008 > Which should come first?
Author Thread: Which should come first?
Username: Crayola0
Portage, Wisconsin
Post Number: 2417
finnaly gettin a steady money flow in and gunna be putting in my system soon once i get a couple more paychecks. so the question is should i get the subs first or should i upgrade the front components and amp them?
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3144
Hu, comps+comp amp, subs+sub amp. In that order.
That way you dont halfass your frontstage.
Username: Tatonka
-[Team Audible
Insanity]-
Post Number: 1988
Jake got it right.
You will enjoy your system ALOT more if you have a decent front stage.
Username: Crayola0
Portage, Wisconsin
Post Number: 2418
alright i have my hu already installed and everything i just wasnt sure. any suggestions on comps and comp amps? around 300 would be awesome
Username: Skibum12189
Cleveland
Post Number: 2941
"Hu, comps+comp amp, subs+sub amp. In that order.
That way you dont halfass your frontstage."
the guy knows what he's talking about
personally, i absolutely love my diamond HEX's but they might be sold out everywhere bc diamond isn't selling online anymore....i've heard great reviews about certain higher end pioneer and jbl component systems (roughly 200 bucks) and then you could probably pick up a used amp that puts out decent power at 100 bucks maybe a little more.
Username: Ctmike
Ct.
Post Number: 6361
pioneer comps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117238
kicker amp
http://www.sonicelectronix.com/item_6569_Kicker+ZX250.2.html
St. Louis, MO / ASU
Post Number: 3147
Jaymes is there anyway you can bump your budget up to $400?
Your options would double and then you could get a little nicer set of comps. Theres a guy on CA selling a kicker zx350.2 for like 160shipped and it seems to be in great shape.
Username: Crayola0
Portage, Wisconsin
Post Number: 2419
i could bump my budget up a lil more but i have to buy new
Home > Message Board > Car Audio > Subwoofers > Archive through July 21, 2008 > Which should come first? [ « Previous ] [ Next » ]
