Home > Message Board > Car Audio > Subwoofers > Archive through July 21, 2008 > Could this work?
Author Thread: Could this work?
Username: Ducka
Shelby Township, MI
United States
Post Number: 332
My friend wants me to help him out with a system and he wants to build a box out of steel welded under his truck so that the floor would be the front baffle with a port built into the box. The front would be the steel floor of the truck and the rest would be made out of like 1/8th or 1/4 inch steel. Would that sound bad? I kinda think that it would but im not a pro.
Username: Van_man
Boston South, MA
Post Number: 4145
yes, it will work. CA7E did something thing like that, but they made it of of fiberglass, and the sub was flush mounted on the floor.
Username: Ducka
Shelby Township, MI
United States
Post Number: 333
but can a box made of steel work?
Username: The_image_dynamic
San Diego, California
Post Number: 4338
It should sound fine if he can stop any metal-to-metal rattling and lines the box with polyfill.
Username: Hittin1
Lake Charles, La.
United States
Post Number: 752
i would really like to hear something like that in person... Would be interesting.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3133
Glass it...
Username: Safe_cracker
Chicago, IL
US
Post Number: 4681
No it won't work and has been done before. Reason being is that most metals resonate within our audible hearing level, hence the metal would ping like a b!tch. I have personally seen boxes made out of diamond plate 1/4' aluminum with a lot or reinforcement and as a sealed enclsoure lined with a lot of dyna it works fine but ported it sounds bad, real bad... Polo.
Username: Ducka
Shelby Township, MI
United States
Post Number: 335
so you think it would be alright so long as it wasnt ported and is stuffed with pollyfill?
Username: 04redmach1
Es DEALER, GA
Post Number: 2183
I would say build it out of wood, and use Rhino-line or a Polyurethane spray.
Kevin
Username: Ducka
Shelby Township, MI
United States
Post Number: 336
yeah that idea came up too.
Username: Van_man
Boston South, MA
Post Number: 4147
in the mag, it was made from MDF and glassed on the outside
Post Number: 4342
Polo -- there is a huge difference between aluminum and hardened steel plate. The resonant frequency of plate steel is far above the cutoff point of these drivers. Like I said above, the main thing is to eliminate any metal-to-metal rattling in mounting the box and to tame the internal reflections by using generous amounts of polyfill.
Username: Ducka
Shelby Township, MI
United States
Post Number: 337
I think we might make the box in mdf then cover that with the steel then weld it in the floor.
Diamond Member
Post Number: 21789
if you set your mind to it then it will work. just believe.
Username: Ducka
Shelby Township, MI
United States
Post Number: 338
hahaha I'll just pray to luck.
Home > Message Board > Car Audio > Subwoofers > Archive through July 21, 2008 > Could this work? [ « Previous ] [ Next » ]
