Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Best amp to push a jl 12 w7in a seale...
Author Thread: Best amp to push a jl 12 w7in a sealed box
Username: Munchy6132
i have a jl 12w7 and i need help deciding which is the best amp to get. please help i already have a memphis 16-mcd 1000 and it did hardly anything so all suggestions are welcome!!!
Username: Ctmike
Ct.
Post Number: 6352
post a budget, and i believe i gave my suggestion in the other thread.
Post Number: 7
thank you again ctmike the best amp under $450
Username: Me123456
Post Number: 31
im looking for the same thing but i need something to puch 2 of them look up us amps that what im lookin at they have a 1000 watt one that would do the job
Username: Killa
Post Number: 13
I suggest some old 1000bd rockford punch amps if you can find them. Their similar the the 800a2's but their very small and 1000w RMS.Not shure if you can find it cheep tho.
Username: 04redmach1
Es DEALER, GA
Post Number: 2194
You will need something with good power at 3 ohm. Look at the Phoenix Gold 1200.1, JBL 1200, or JL 1000/1. It isn't going to be cheap.
Kevin
Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Best amp to push a jl 12 w7in a seale... [ « Previous ] [ Next » ]
