Thread: LOC |
Bronze Member Username: Will4992
NC
Post Number: 32 Registered: Mar-08
| Posted on Thursday, July 17, 2008 - 04:09 pm: |
Can someone just explain how to install a line out converter. also, are there any downsides to using them? |
Silver Member Username: Gibsonguy
Storrs,
CT
Post Number: 308 Registered: May-08
| Posted on Thursday, July 17, 2008 - 04:17 pm: |
There really arent too many downsides to using a LOC. unless you plan on buying a new HU, it's the best way to go. and you will have to splice into existing speaker wire, then run rca's from the LOC to your amp. that's pretty much all there is too it. |
NC
Post Number: 33 Registered: Mar-08
| Posted on Thursday, July 17, 2008 - 04:25 pm: |
http://www.sonicelectronix.com/item_11288_SoundGate+LOC4.2.html# would this be a good one to go with. |
Storrs,
CT
Post Number: 309 Registered: May-08
| Posted on Thursday, July 17, 2008 - 04:29 pm: |
what are you using your loc for? |
NC
Post Number: 34 Registered: Mar-08
| Posted on Thursday, July 17, 2008 - 04:38 pm: |
im using it instead of getting a new HU. I have no idea what kind of loc to get or where to get it though. |
Storrs,
CT
Post Number: 310 Registered: May-08
| Posted on Thursday, July 17, 2008 - 04:42 pm: |
if you're just trying to add a subwoofer, you can get a much cheaper one than that. |
NC
Post Number: 35 Registered: Mar-08
| Posted on Thursday, July 17, 2008 - 04:49 pm: |
Do you have any ideas of good companies to buy them from. maybe one of these? http://www.sonicelectronix.com/item_11289_SoundGate+LOCPRO.html http://www.sonicelectronix.com/item_4994_Scosche+LOC-80+Adjustable+Line-Out+Conv erter.html |
Storrs,
CT
Post Number: 311 Registered: May-08
| Posted on Thursday, July 17, 2008 - 05:08 pm: |
actually, the owner of RD Audio just posted in another thread that he has a TON of install accessories for sale. im sure he could hook you up at a really good price. the thread title was something about a 0/4 gauge distribution block. so just look at that thread and read steve miller's post. |
Silver Member Username: Charlesbhs
Dallas,
Tx
Post Number: 623 Registered: Jan-07
| Posted on Thursday, July 17, 2008 - 05:20 pm: |
hey i got a question about LOC's, for the Scosche one(think thats the one i have) what should i have the 2 gains set too? like qtr way? half way? |
