Thread: Ot: Anyone here a webmaster? |
Silver Member Username: Gibsonguy
Storrs,
CT
Post Number: 294 Registered: May-08
| Posted on Wednesday, July 16, 2008 - 09:38 pm: |
so im trying to get my site up and running, but i have like zero html skills. anyone here know what they are doing when it comes to this that could help me out? it's just one little problem im having, linking pages together. |
Gold Member Username: Extrmndor3
Http://illuzonemu.serv...,
^^^Sick Game
Post Number: 7964 Registered: Feb-06
| Posted on Wednesday, July 16, 2008 - 10:02 pm: |
heres my website
http://illuzonemu.servegame.com and crazydbs.freehostia.com |
Storrs,
CT
Post Number: 296 Registered: May-08
| Posted on Wednesday, July 16, 2008 - 10:06 pm: |
well im sure you could help me out if you're interested? |
Gold Member Username: Tatonka
-[Team Audible
Insanity]-
Post Number: 1958 Registered: Mar-07
| Posted on Thursday, July 17, 2008 - 01:20 am: |
I'm pretty good when it comes to web design  |
Storrs,
CT
Post Number: 298 Registered: May-08
| Posted on Thursday, July 17, 2008 - 10:09 am: |
well i've been having a slight problem with dreamweaver. whenever i add a link, it screws up the formatting on my page. everything gets out of line. have any idea why this is happening? |
-[Team Audible
Insanity]-
Post Number: 1962 Registered: Mar-07
| Posted on Thursday, July 17, 2008 - 11:22 am: |
Are you adding a link to a button or what? |
Storrs,
CT
Post Number: 299 Registered: May-08
| Posted on Thursday, July 17, 2008 - 11:31 am: |
yeah, im just adding a link to an image. when i add a link in photoshop using the slice select tool, it works fine. so i can link to other sites already on the internet. but when i have 2 pages i made, and try to link them together in dreamweaver it screws up the page. |
-[Team Audible
Insanity]-
Post Number: 1963 Registered: Mar-07
| Posted on Thursday, July 17, 2008 - 03:45 pm: |
Well, when you add a link to an image, it will defualtly try and put a "border=2" in that line of code. What you need to do is change the number to 0. |
Storrs,
CT
Post Number: 306 Registered: May-08
| Posted on Thursday, July 17, 2008 - 03:47 pm: |
ohh i see....ill try that. also, i think i know who you are. are you the same nick v who made the low-hz site? because im getting my site hosted through them. if you are, you may see what im working on. |
Storrs,
CT
Post Number: 307 Registered: May-08
| Posted on Thursday, July 17, 2008 - 03:54 pm: |
nowhere right around that button did i see any type of boarder=2. would the code that says boarder=2 be around the same place as the html code for that button is? or should i search the entire code for boarder=2 and change each one to 0 to see if anything good happens? |
-[Team Audible
Insanity]-
Post Number: 1965 Registered: Mar-07
| Posted on Thursday, July 17, 2008 - 07:16 pm: |
Search the code for "border=" I'm not sure of the default border number for dreamweaver. If it is not there, insert "border=0" after the link info that is between brackets for every button. |
Gold Member Username: Tejcurrent
Post Number: 1418 Registered: Apr-07
| Posted on Thursday, July 17, 2008 - 09:10 pm: |
The border=0 code could be either in the table (assuming you're using a table), or it could be the image. There could be a couple things associated with that particular link. Is there a style sheet (css) or script affecting things? I'd check and make sure there isn't something like that causing your problem. Then go into the image and add border=0 even if you don't see a border= tag. Try it in a couple places right near the problem link/image until it goes away. If it doesn't and you've tried like 3+ tags then ask back and we'll try and figure something else out. |
Post Number: 1419 Registered: Apr-07
| Posted on Thursday, July 17, 2008 - 09:12 pm: |
