Home > Message Board > Car Audio > Subwoofers > Archive through July 21, 2008 > Okay im stumped idk why it wont work
Author Thread: Okay im stumped idk why it wont work
Username: Chris19
Howell, New jersey
Monmouth
okay i own 2 12" w6 subs and a jl audio 1000/1 amp i just put it back into my car my remote wire is snug ground is snug and hot is snug as well everything is good i just replaced my chassis ground used a #8 sqrew it's going into my compasitor first no bump or any movement from my subs someone help me please
Username: Hittin1
Lake Charles, La.
United States
Post Number: 716
check:h.u settings, rca's, power light on amp,fuses, chassis ground---multiple screws on a bare metal (sanded)surface.
Username: The_image_dynamic
San Diego, California
Post Number: 4323
Take out the capacitor. You don't need it, and if it isn't charged it will be a dead short and blow your fuse.
1. Remove capacitor
2. Check your fuses
3. Check that your ground wire is contacting metal and not paint
Username: Shade
Moxee, Wa
U.S.
Post Number: 677
does ur amp power on?
do u have RCA's plugged in?
did u put ur fuse back in by ur battery?
is the sub option on your headunit turned to OFF?
do u have ur speaker wires plugged into the amp and the subs?
Username: Shade
Moxee, Wa
U.S.
Post Number: 678
if u have checked all of this and still nothing...send me your amp and subs and i will find out the problem for u free of charge :-)
Username: Hittin1
Lake Charles, La.
United States
Post Number: 719
lol
Username: Chris19
Howell, New jersey
Monmouth
yes i took my head unit out to make my remote wire was well crimped it was and the rca cable were good but im going to check my ground again sand it down more and take the compasitor out ill let u know how everything goes
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2444
CAPACITOR* ......Fùck!!!
Ever hear of periods?????Upload
Username: •cam•
BC
Post Number: 2530
^Ever been on PinkBike? It's just as bad, man. Frickin' terrible. Um. I have nothing useful to contribute.
Username: Moey_g
Sydney
Australia
Post Number: 255
Have you checked the voltage at the amp with a multimeter?
Username: Evildoughboy08
Toledo, OH
US and A
Post Number: 98
whatever you replaced (chassis ground)
put it back the way it was, and see if it works then.
if not, then all i can say is to do what jeremy said.*not send him the subs and amp* lol
Home > Message Board > Car Audio > Subwoofers > Archive through July 21, 2008 > Okay im stumped idk why it wont work [ « Previous ] [ Next » ]
