Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Need some help?
Author Thread: Need some help?
Username: Me123456
Post Number: 30
ok i have 2 12inch w7 and im looking for a 2000 watt amp to push them instead of buyin two 1000/1 what do you thiknk is a good amp to get for about $650?
Username: Bonhamd
TC, MI
Post Number: 853
i think those come in single 3 ohm, then wired to 1.5 ohms
if that is the case - you will need an amp that will do a little more than 2000 into 1 ohm
Rockford Fosgate T20001bd - you can probably get a refurb in your budget
orion 2500.1
im sure someone else here can give you a lot of suggestions on an amp within your budget
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5406
talk to kevin holden
Username: Somedonniedude
Illinois
United States
Post Number: 1853
http://low-hz.com/
Kevins email is in the link, also look into some of the amps in the link.
Username: 04redmach1
Es DEALER, GA
Post Number: 2180
You can email me direct at:
lowhz01@yahoo.com
Kevin
Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Need some help? [ « Previous ] [ Next » ]
