Home > Message Board > Car Audio > Head Units > Archive through August 01, 2008 > XDVD710?
Author Thread: XDVD710?
Username: Profiler99
i just got it installed over the weekend.
they put in a bypass swicth but still does not play dvds. i tried entering the code but no play. can someone help out.
Username: The_image_dynamic
San Diego, California
Post Number: 4316
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
** Take out Audio CD and Insert a DVD
Thanks for the feedback, but its still doing the same thing. Do you thing its the way they did the install?
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1382
chances are to do what brad posted you will have to ground the units parking break wire.but i'm not going to say how , it's illegal. btw u do realise ur car must have th emergencey brake enabled to play dvds thats how it works.
Username: Antidestro
http://forum.ecoustics.com/bbs/messages/4/302701.html
Dual has a unique sequence of on/off for the parking brake (it will be in your instruction manual) either way flip the switch so that your parking brake wire is grounded then do your bypass sequence code... but yeah, it is illegal to drive and watch movies in plane view of the driver...
Home > Message Board > Car Audio > Head Units > Archive through August 01, 2008 > XDVD710? [ « Previous ] [ Next » ]
