Thread: Amp installation |
Silver Member Username: Moheevi
Post Number: 140 Registered: Mar-06
| Posted on Friday, July 11, 2008 - 04:02 pm: |
I'm about to install an amp in my car. I was wondering if I could put the fuse close to the amp instead of close to the battery on the power wire. Would this be a bad thing to do? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7908 Registered: Jul-06
| Posted on Friday, July 11, 2008 - 09:37 pm: |
Very bad that defeats the purpose of the fuse, to protect the wire. If you don't put a fuse near the battery and the wire shorts it WILL burn, likely starting a fire..... |
Silver Member Username: Wylie_coyote
Post Number: 188 Registered: Apr-07
| Posted on Monday, July 14, 2008 - 11:33 am: |
yeah dude, i didn't understand this properly for a while myself. i thought the fuse was there to protect the amp but its not its there more for the overall safety of the car and battery. |
New member Username: Pitstop_mobile_audio
Springfield ,
Missouri
United states
Post Number: 1 Registered: Jul-08
| Posted on Tuesday, July 15, 2008 - 10:46 am: |
if your not running mecca car audio competitions than just put the fuse by your battery. if you are running shows you must place the fuse 18 inches from your amp. |
