Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Help finding the best car speakers an...
Author Thread: Help finding the best car speakers and tweeters on a budget!?
Username: Bryansuavo
ok so im almost positive i am getting this head unit:
Pioneer DEH-P6900UB
* Peak Power Output: 50 watts x 4 channels
* RMS Power Output: 22 watts x 4 channels
* Preamp Voltage: 4 volts
* CD Signal-to-Noise: 94 dB
i will be powering the speakers with my head unit unless you guys recommend a good amp for this, but im lets say under a 200 dollar budget and maybe less, and i wanted to know what are the best set of 2-way car speakers i can buy and a set of tweeters i could buy under this budget, and maybe include an amp for theses speakers and another set of 2way speakers for the back(not as good as the front speakers of course) but still good, but this are secondary and out of budget per say.. anyone please help?
also they have to be 6.5's! thanks!
Username: Exige
CDT, Audiopulse Dealer
Post Number: 487
skip the rear speakers. up your budget a little bit....can you do 300? it'd be well worth it. you'll have some good options at that price point. let us know if you can.
sure what can i get for 300?
Username: Exige
Post Number: 497
It will allow you to get an amp. I'll PM you a couple combinations that would work well.
im eager to find out :D! thanks for the help!
Username: Exige
Post Number: 507
Did you check your PM's? Email me at mike@exigeaudio.com if you haven't received anything!
Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Help finding the best car speakers an... [ « Previous ] [ Next » ]
