Thread: How big? |
New member Username: Cg618
Post Number: 1 Registered: Jul-08
| Posted on Wednesday, July 09, 2008 - 10:48 am: |
I have an older w6 and a w3 im wanting to go bigger and get 2 new W6's how big of an amp should i get and what kind? Thanks Cody |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7891 Registered: Jul-06
| Posted on Wednesday, July 09, 2008 - 11:07 am: |
JL 1000/1 |
Post Number: 2 Registered: Jul-08
| Posted on Wednesday, July 09, 2008 - 12:00 pm: |
thats only 1 channel and im gonna have 3 hooked up lol how sdoes that work? |
Northwest PA
Post Number: 7894 Registered: Jul-06
| Posted on Wednesday, July 09, 2008 - 12:22 pm: |
You only need one channel for subs, just connect them both. And you'd only have 2 hooked up if you go with the W6s. DON'T ever mix different subs. |
Post Number: 3 Registered: Jul-08
| Posted on Wednesday, July 09, 2008 - 12:29 pm: |
oh i thought i needed 1 channel per sub...ok i wont thanks lol will that divide to 500 each or whatsup? |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1608 Registered: Mar-04
| Posted on Wednesday, July 09, 2008 - 01:14 pm: |
The 1000/1 will deliver 1000w into any impedance between 1.5 and 4 ohms. If you have 1 4 ohm sub connected it will get 1000w. If you have 2 4 ohm subs connected in parallel (2 ohms) they will each get 500w. If you have three subs connected you'd want them to either be dvc 4's wired for 2.67 ohms or dvc 2's wired for 3 ohms - either way you'd get 333w per sub. I also agree though - don't mix w3's/w6's. |
Post Number: 5 Registered: Jul-08
| Posted on Wednesday, July 09, 2008 - 01:37 pm: |
lets say my w6's are Dual 4 ohm only on both so each ohm will gt 500? |
Northwest PA
Post Number: 7896 Registered: Jul-06
| Posted on Wednesday, July 09, 2008 - 02:34 pm: |
Each sub gets 500w as long as you wire them right |
Lawrence,
Ks
Post Number: 1609 Registered: Mar-04
| Posted on Wednesday, July 09, 2008 - 03:41 pm: |
