Thread: 0 to 4 Awg Fused Distribution Block |
Bronze Member Username: Cozce
Post Number: 81 Registered: Mar-08
| Posted on Tuesday, July 08, 2008 - 06:20 pm: |
Can someone give me a link to a good one? Also would this work with it, http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6440 ? Need a 200-250 amp fuse. |
Post Number: 82 Registered: Mar-08
| Posted on Tuesday, July 08, 2008 - 06:35 pm: |
http://cgi.ebay.com/Stinger-PRO-1-0-to-4-Ga-Dual-ANL-Fuse-Block-SFPD2ANL_W0QQite mZ130065421746QQihZ003QQcategoryZ50551QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_tr ksidZp1638Q2em118Q2el1247 Or can I do better? |
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6503 Registered: Mar-04
| Posted on Tuesday, July 08, 2008 - 07:26 pm: |
http://sonicelectronix.com/item_11177_Phoenix+Gold+TXBBKF2.html Pretty much the same thing, just ~$25 cheaper and uses Mini-ANL fuses. One thing though...I would NOT fuse 4ga wire at 200a+ |
Post Number: 83 Registered: Mar-08
| Posted on Tuesday, July 08, 2008 - 07:31 pm: |
"One thing though...I would NOT fuse 4ga wire at 200a+" Idk I'm going to be running about 1500rms, if my electrical can manage, off a saz-1500d. Jake papa, suggested that I get a 200-250 amp fuse, and a 1/0 to 4awg disto block...4-gauge wouldn't be able to handle 1000-1500 watts rms? |
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6504 Registered: Mar-04
| Posted on Tuesday, July 08, 2008 - 07:47 pm: |
A 150A ANL will do w/ that 4ga. Just keep the run of wire between the distro-block and the amp pretty short. |
Gold Member Username: Philly306
James Carrol is the re...
Post Number: 1175 Registered: Apr-07
| Posted on Tuesday, July 08, 2008 - 07:59 pm: |
yea i believe jake was referring to the fuse at the battery being 200-250 for the 1/0. You will need a ~150A like canaan said for the 4g after the dist block. |
Post Number: 84 Registered: Mar-08
| Posted on Tuesday, July 08, 2008 - 08:10 pm: |
Would it be a problem getting Scosche? http://sonicelectronix.com/item_10588_e2+EANL250+by+Scosche.html |
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6507 Registered: Mar-04
| Posted on Tuesday, July 08, 2008 - 11:04 pm: |
If you get the Phoenix Gold distro I recommended, you will need a Mini-ANL. Check out KnuKonceptz.com for Mini-ANL's. http://cgi.ebay.com/KnuKonceptz-Midi-Mini-ANL-150A-Fuse-5-Pack_W0QQitemZ32021359 3819QQihZ011QQcategoryZ50551QQcmdZViewItemQQ_trksidZp1742.m153.l1262 There is a 5-pack of the 150a's. |
Silver Member Username: Killswitchjd
Post Number: 768 Registered: Apr-06
| Posted on Wednesday, July 09, 2008 - 11:02 am: |
I never fuse after the distribution block. only one big one after the battery. No fires or fried amps yet so its a good sign |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7895 Registered: Jul-06
| Posted on Wednesday, July 09, 2008 - 12:24 pm: |
Any time you reduce the size of a wire it MUST be fused. Unless the smaller length is VERY short. |
Bronze Member Username: Beamerboy46350
LaPorte,
IN
United States
Post Number: 66 Registered: Jun-08
| Posted on Thursday, July 17, 2008 - 06:04 am: |
A wire without a fuse is a fusible link. Thats why you hafta fuse when stepping down. Otherwise the wire is the fuse. |
Silver Member Username: Teamrevolution
ATLANTA,
GA
Post Number: 312 Registered: May-07
| Posted on Thursday, July 17, 2008 - 01:55 pm: |
I can help you if you want http://www.scosche.com/products/sfID1/160/sfID2/165/sfID3/253 PDMWF2D along with two minni fuses for 30.00 shipped or One of there large iced Anl fused blocks that retails for 69.99 it has 0 in and two 0 out with two anl fuses for 37.00 shipped. I have boxes of install stuff since before i owned RD i had two retail shops and was a distributor. Currently have over 50 rolls of wire ranging from 0 guage to 10 g. and over 100 sets of http://www.scosche.com/products/sfID1/160/sfID2/266/sfID3/257 the A17twd ones and over 150 sets of the tsunami 20ft 199.00 msrp rca's the rtp13.9 ones Tons and tons of install stuff just siting in boxes |
Silver Member Username: Gibsonguy
Storrs,
CT
Post Number: 305 Registered: May-08
| Posted on Thursday, July 17, 2008 - 03:45 pm: |
need someone to sell it for you?
