Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Rearfill - midbass or full range
Author Thread: Rearfill - midbass or full range
Username: Blue1ce
Hello everyone i am currently putting together an audio system and i need some advice i have researched for the past month on what im going to buy. my budget is 900-1100 ( for all the new stuff )
I already bought a Kenwood X792 headunit and Focal 165A comps and i need some advice on rear fill for a saturn sl
i plan on getting a Rockford Fosgate Power-1000 25 to life amp($500), Alpine type r($140), with a 2^3 ft box tuned to 32hz ($120), wiring fuses etc(120-200$)
$880
so i plan on spending 100-200 on rearfill
i can set my headunit for high pass for rear and my amp on low pass for midbass on rear or just get full range speakers. any suggestions for my amp setup etc are welcomed also.
(Edit: 6 1/2"s in the rear)
Username: Exige
CDT, Audiopulse Dealer
Post Number: 473
Do you carry a lot of passengers around in the back? If not I would go with midbass. Check your PM's. I will send you a couple hints for wiring and box building and stuff as well.
Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Rearfill - midbass or full range [ « Previous ] [ Next » ]
