Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Looking for 6x8's
Author Thread: Looking for 6x8's
Username: Fritos2
Post Number: 18
just wondering wat u guys think would be the best speakers to use for 6x8's or if 5x7's would fit or w.e but im looking to spend 150 or lower for 4 speakers and using aftermarket headunit wich i believe is 40x4 watt looking at these at the moment
Hifonics ZXi 683, Rockford Fosgate Punch P1683C, Pioneer TS-A6881R
Username: Exige
CDT, Audiopulse Dealer
Post Number: 472
Skip 6x8's. Can you fit 6.5" speakers via an adaptor? These would be a much better bet for you. What kind of car are these going into? Consider getting a set of speakers just for the front and spending the extra money on an amp. An amp with a decent set of 6.5" speaker will do you wonders.
Username: Fritos2
Post Number: 20
im not sure if i can fit 6.5's ill look tomorrow a 94 explorer its goin to
Username: Exige
Post Number: 475
alright just let us know
Username: Fritos2
Post Number: 28
i took 2 pictures of a tape measure on each side bout how far it goes but i dont have a usb to get the pics from phone to the comp atm so 2nite maybe i can get them or just take pics witha cam later. the 6.5 would be like coming over the edge where the screws for the mount atm is, but it looks like it mite fit, and in the manual for the headunit it said 20x4w :-( so if its cheaper for a new headunit instead of amp i wouldnt mind that
Username: Exige
Post Number: 476
Just send your pics to my email and I'd be happy to help you out with it. Where you would normally type in the phone number to send the pictures to...just put my email address in and you'll be good to go: sales@exigeaudio.com
I'll have a look and let you know what I think.
Username: Fritos2
Post Number: 36
ive heard a lil bout cdt, i would like to spend less then $150
Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Looking for 6x8's [ « Previous ] [ Next » ]
