Thread: 2004 grand am with monsoon system i need help with a line converter |
New member Username: Peteracer
Post Number: 2 Registered: Jul-08
| Posted on Wednesday, July 02, 2008 - 03:30 pm: |
i have a 2004 grand am with the monsoom system in it. how do i put in a 4 channel line converter. i ran all new wires and replaced all the speakers. i have a 4 ch. amp in the trunk that wont shut off all so because i dont know where to hook up the remote wire. please help!!!!!! |
Bronze Member Username: Vivi2000
Post Number: 55 Registered: Aug-07
| Posted on Wednesday, July 02, 2008 - 09:04 pm: |
Hook up the remote wire to your stereo turn on fuse, or another fuse that does not give power when the car is off. |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 4656 Registered: Jan-06
| Posted on Thursday, July 03, 2008 - 02:59 pm: |
PAC makes an adapter that attaches to the back of the HU and gives you either 2 or 4 channel out capability (dependant on PAC adapter model). Using line converters will not work for the Bose or monsoon, they have controlls within the HU and system amplifier to control output/frequencies, keeps you from blowing your sh!t. Doing the converter you will never have the needed output for your sub(s) trust me I have been that route huge difference when doing it right. Polo. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7855 Registered: Jul-06
| Posted on Thursday, July 03, 2008 - 03:25 pm: |
Advanced factory systems suck azz.... like Polo said simply using a line out converter doesn't work |
Chicago,
IL
US
Post Number: 4657 Registered: Jan-06
| Posted on Thursday, July 03, 2008 - 10:07 pm: |
BTW the PAC adapter even though kinda pricey, it also gives you a remote turn on for amps and has level controls and amp turn on delay, great unit. I have one I can sell you if I can find it but you will need to pruchase the apropriate manufactures cable to plug into the back of your factory HU, price $80, paid twice that....Polo. |
