Thread: Does the gain knob actually gain anything ? |
Bronze Member Username: Beamerboy46350
LaPorte,
IN
United States
Post Number: 27 Registered: Jun-08
| Posted on Tuesday, July 01, 2008 - 06:41 am: |
Does adjustent of the knob change wattage?? Like if the minimum setting is 4 volts then does it produce all of its power at that setting or do i have to turn it to 1 volt to get all of the power ?? |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1596 Registered: Mar-04
| Posted on Tuesday, July 01, 2008 - 09:46 am: |
the gain adjusts the input sensitivity to match the pre-amp voltage of the HU. If your HU is 2v, then somewhere in the 1-2v range on the gain will get full power out of the amp (1-2 because the HU won't actually produce 2v until it's at or near full volume). If your HU is 4v the gain should be at the 3-4v range. Setting the gain "louder" (lower voltage) won't produce more power. The amp will just reach full power at a lower volume setting on your HU, and going above that will only clip the amp and sound awful |
Gold Member Username: Carguy
Post Number: 6937 Registered: Nov-04
| Posted on Monday, July 14, 2008 - 01:25 pm: |
It will also blow the amp. |
Bronze Member Username: Blaaaahhhhh
Warrior,
Alabama
Usa
Post Number: 65 Registered: Jan-08
| Posted on Monday, July 14, 2008 - 02:48 pm: |
This thread really helped me, I've read so much stuff to try and figure out how to set my gain right and you guys pretty much summed it up. Thanks |
Silver Member Username: Ridinspinnas
Windsor,
Ontario
Post Number: 325 Registered: May-06
| Posted on Wednesday, July 23, 2008 - 07:34 pm: |
ur welcome  |
