Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Boss Amp Wiring Help
Author Thread: Boss Amp Wiring Help
Username: Radrhino07
Humble, Tx.
I was given a lil 400 watt 4 channel amp. I want to hook 2 10" subs to it. Do i hook 1 sub to the channel 1 positive and channel 2 negative. And the other to channel 3 positive and channel 4 negative or what. Please help.
Username: N2audio
Lawrence, Ks
Post Number: 1595
if they're standard 4 ohm subs you can bridge each pair of channels. It might be done the way you explained, but not all amps are the same. It should be identified on the speaker outputs which terminals are used to bridge the amp
Username: Beamerboy46350
LaPorte, IN
United States
Post Number: 18
A model number would help
Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Boss Amp Wiring Help [ « Previous ] [ Next » ]
