Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Whats better
Author Thread: Whats better
Username: Rtyauch301
Post Number: 250
ok so my car only has holes for 4X6's in the door so what will sound better 4X6 plate speakers or just regular 4X6's
Username: Exige
CDT, Audiopulse Dealer
Post Number: 457
Can you expand the holes to fit 6.5" speakers? Not too many companies make 4x6 speakers and those that do are not that great.
Post Number: 251
no i cant expand it to a 6.5 theirs not enough room i have thought about putting it in the outside of the door were their is enough room but the factory grill is to long i think its 7" at the longest point so i was wondering if 6X8 would sound better because i would like a a component set
Username: Exige
Post Number: 459
start with this: what's your budget for everything? from there we can figure out what will work best.
Post Number: 252
the best i can do is $150 for a set of mid's
Post Number: 254
nm i found this what is a good set of 6.5's for that price http://cgi.ebay.com/4x6-to-6-5-6-Speaker-Adapter-97-05-Malibu-Grand-Am_W0QQitemZ 310061982747QQihZ021QQcategoryZ14932QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Exige
Post Number: 467
Good find. Check your PM's. There's some good stuff there.
Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Whats better [ « Previous ] [ Next » ]
