Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Help
Author Thread: Help
Username: Intenz
Barstow, Ca
U.s.a.
how do i install two amps, one to power the door speakers, and the other two power the sub ?
Username: Snowball123
West Allis, WI
United States
Post Number: 913
run whatever gauge wire to a distribution block and then the distribution block distributes one power wire to sub amp and one power wire to comp. amp, then ground each of the amps. not hard.
Username: Nd4spd18
Northwest PA
Post Number: 7838
That or just run 2 power wires
Username: Vt_ahole
Post Number: 99
does it make a difference? running two seperate power wires or one to a dist block?
Username: Insearchofbass
Post Number: 9821
as long as the power wire is good enough for the total amperage running through it you would be better off to run one power wire and a distribution block and a power wire from there to the other amp
Username: Mario_silva
COATZACOALCOS, VERACRUZ
MEXICO
Post Number: 28
make sure ground wires goes to the same point of your chasis.
Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Help [ « Previous ] [ Next » ]
