Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Blown Rockford Fosgate T10001bd amp?
Author Thread: Blown Rockford Fosgate T10001bd amp?
Username: Mackevion
Post Number: 35
I need help. Recently I blew the fuse on it, and replaced it, however since then the amp has not worked. Whenever I try to hook the remote wire up the speakers in the car (not my subs) make a loud squealing sound. Could the amp be blown? Is there any tests that I can to do see if this amp is blown?
Username: 04redmach1
Columbus, GA
Post Number: 2100
Did you blow all the fuses on the amp and replace them, or did you blow the inline fuse on your wire?
When you hook the remote wire up to power the amp up, it starts making noises as soon as turned on? How did you hook everything back up?
Kevin
Username: Mackevion
Post Number: 36
From my knowledge, there is only one 150a fuse on the amp. I did not blow the inline fuse.
The amp is only powering 1 12 and its a pretty simple hookup power, ground then remote. And yes, the amp starts making the noise immediatedly after I plug the remote wire up.
Columbus, GA
Post Number: 2107
Hmmm, hard to say without being there. I would stop by a local shop and let them look at it and see what they say. Could be too many things to list.
Kevin
Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Blown Rockford Fosgate T10001bd amp? [ « Previous ] [ Next » ]
