Thread: PRoperly setting Gain, Sub Out Level, and crossover level and settings |
New member Username: Beamerboy46350
LaPorte,
IN
United States
Post Number: 9 Registered: Jun-08
| Posted on Wednesday, June 25, 2008 - 06:04 am: |
What excactly is the correct way to set these things? I do not have an oscilloscope but i have a Digital multi meter. I have blown 3 subs and an amp in the last 6 months after doing alot of reading on here im 100% sure ive been "clipping" Currently I have a brand new kenwood KDC-635, A soundstream amp model XTA880.2 which is # RMS Power (4 ohms): 220 watts x 2 ch. # RMS Power (2 ohms): 440 watts x 2 ch. # RMS Power (1 ohm): Not Stable # Bridged RMS Power: 880 watts # Peak Power Output: 1760 watts approx. # Min. Impedance Unbridged: 2 ohms # Min. Impedance Bridged: 4 ohms and a prefab bandpass box made by dub mag audio for 2 12's and 2brand new cuspid 12" 600w max subs and a pyle subwoofer crossover model PLXR-2 the head unit has a sub out control of -15 through +15 then the crossover has a "variable gain adjustment no numbers just like a 180 degrees of adjustmentit says level then it has a 3way switch for crossover point of either 50 90 or 180 hz then a bass boost of 12 db on or off at 45 80 or 120hz then the am has a gain control plus high and low pass filter and another 18 db of bass boost can antone help to tell me how to set all these things properly I was setting them all at like 75% but as ive went through 3 subs and an amp im inclined to think i was wrong N E HELP IS GREATLY APPRECIATED |
Bronze Member Username: Basshead4life
Iowa
Post Number: 14 Registered: Jun-08
| Posted on Wednesday, June 25, 2008 - 08:17 am: |
this time keep that bass boost off, with it on max (presume u had it maxed) it sent more power and heat to the subs causin them to blow, ok first off set your hu to 3/4 of max volume, set your gain with a 60 hz 0 db tone or 50 hz 0 db tone, since most dmm's are accurate at that frequency, put sub level on +15 so u get all your head units preout voltage for a accurate signal, put crossover at 50 hz or 90 hz, if using the 50 hz use a 50 hz 0 db test tone and raise gain till u hit what your subs rms rating is, and keep that other 18 db bass boost off, ur bass will be much cleaner. i had a soundstorm amp and it was a remote gain, it had a 0-18 bass boost switch to it and it wasn't variable. hope all this info helps Also what is your subs RMS rating?, if u tell me that i can tell you what you need to set your gain too in volts. |
