Thread: Amplifier fuse keeps blowing ?? |
New member Username: Beamerboy46350
LaPorte,
IN
United States
Post Number: 6 Registered: Jun-08
| Posted on Tuesday, June 24, 2008 - 04:29 pm: |
What would make the fuse in the amplifier blow ?? IT is happening when i hook up power to the amp. before subs hooked up befpre remote lead turned on just hooking it up. I tried disconnecting power then putting in fuse ? still blows when hooked back up. I dont know alot about the internals of amps but im sure its hooked up right |
Silver Member Username: Hittin1
Lake Charles,
La.
United States
Post Number: 495 Registered: May-07
| Posted on Tuesday, June 24, 2008 - 07:06 pm: |
what amp are u using? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7813 Registered: Jul-06
| Posted on Tuesday, June 24, 2008 - 07:49 pm: |
Reversing the + and - would cause that..... but if it's wired correctly then the amp must be bad. |
LaPorte,
IN
United States
Post Number: 8 Registered: Jun-08
| Posted on Tuesday, June 24, 2008 - 09:16 pm: |
so lets say i reversed + and - saw my mistake and now every amp hooked up to this power cord blows fuses |
Bronze Member Username: Evildoughboy08
Toledo,
OH
US and A
Post Number: 63 Registered: Jun-08
| Posted on Sunday, June 29, 2008 - 10:42 pm: |
no, then from now on you wouuuuld hook amps up normally, the one you have sounds wierd. |
