Thread: Nedd Help Finding Tuning Frequency of Box |
Silver Member Username: Howtoeatapencil
Post Number: 174 Registered: Mar-08
| Posted on Saturday, June 21, 2008 - 03:39 pm: |
its made from 5/8mdf external dimensions 15" height 25" wide 16.5" deep port is 2" wide and 30" long I feel like this might be a little small for my 12" alpha...what is it tuned at?? is the volume to small? |
Silver Member Username: Hittin1
Lake Charles,
La.
United States
Post Number: 458 Registered: May-07
| Posted on Saturday, June 21, 2008 - 06:40 pm: |
I'm assuming that the port is a rectangle port..need to how how deep the port is. why 5/8 MDF? hope it is well braced. prefab box? What amp you pushing that sub with? just a few questions... l8r |
Lake Charles,
La.
United States
Post Number: 459 Registered: May-07
| Posted on Saturday, June 21, 2008 - 06:45 pm: |
hmmmm. i thing i read wrong or something... how you get a 30" port in that box. Is it an aero port that is internally angled? cant be rectangle port.. (60 sq in) |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7773 Registered: Jul-06
| Posted on Saturday, June 21, 2008 - 06:58 pm: |
prefab box FTMFL |
Post Number: 176 Registered: Mar-08
| Posted on Saturday, June 21, 2008 - 09:57 pm: |
its a 30" slot port that bends.. its not prefab... and i could only find 5/8 so i just doubled most of it, but not all of it, so i gave what the dimensions would be if it was just single 5/8 with the same internal volume. im useing an ample audio 300dx to push it..1500 watts at 1 ohm |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 4103 Registered: Mar-06
| Posted on Sunday, June 22, 2008 - 10:42 am: |
according to the re calc, its 2.371 cubes, tuned to 30.114hz port area, 27.4 |
Post Number: 178 Registered: Mar-08
| Posted on Sunday, June 22, 2008 - 04:51 pm: |
yeha i used that and got the same thing, but will that work for my alpha?? tuned to 30 hz will it get good sq and still hit hard? |
