Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Bass boost?
Author Thread: Bass boost?
Username: Theivan
Dawson Creek, British Colu...
Post Number: 122
jl 500/1 amp with a PG xenon 10" uhm i was told bass boost on amp isnt used because it causes problems and can blow subs? i think it can handle it but i dont want to wreck it how can i test it?????????
Username: Nd4spd18
Northwest PA
Post Number: 7756
Bass boost = clipping = bad
In terms of clipping, turning bass boost way up and turning gain way up have the same effect which is to easily blow subs.
Not only that, it sounds bad. It creates a peak at one frequency which is the opposite of what you want, a flat response.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5379
agree
Username: Theivan
Post Number: 123
nice thanks
Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Bass boost? [ « Previous ] [ Next » ]
