Thread: 2 12 alpine type rs |
New member Username: Truthatenvy
Pittsburgh,
Pa
United states
Post Number: 1 Registered: Jun-08
| Posted on Wednesday, June 18, 2008 - 05:05 pm: |
i got 2 12 alpine type rs 2 ohms with a kenwood 1800 watt amp and im thinking of trying to find another type r and another amp any suggestion on the amp? and is their a big diffrence in sound because my brother has the same subs i do but his is a 4 ohm sub? |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 565 Registered: Sep-07
| Posted on Wednesday, June 18, 2008 - 06:47 pm: |
What car do you have? Have you upgraded your car's electrical? Those question are more important if you plan on running the 3rd type R. You will produce a 1.34ohm load, so basically you would need an amp that does about 2000wrms at 1 ohm, give or take The Audioque (buy direct) 2200D would be a great choice at $400ish, but with stock electrical you can't possible push that much current. |
Pittsburgh,
Pa
United states
Post Number: 3 Registered: Jun-08
| Posted on Wednesday, June 18, 2008 - 07:06 pm: |
i have a 2002 volvo s60 t5 with a stock system(which still hits hard)the guy who had my car before me got the upgrade system and had dolbys put in so even with out subs it shakes my car |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5377 Registered: Dec-05
| Posted on Thursday, June 19, 2008 - 01:25 pm: |
i'd keep two type Rs and sell that kenwood. IMO find a better amp |
Silver Member Username: Bonhamd
TC,
MI
Post Number: 784 Registered: Nov-07
| Posted on Thursday, June 19, 2008 - 01:35 pm: |
maybe a kicker zx1000.1 |
Bronze Member Username: Curious
Post Number: 92 Registered: Dec-05
| Posted on Monday, June 23, 2008 - 11:48 pm: |
Hey fellas i am in the same boat as tony and needless to say my kenwood amp sucks worse than his. what amps do you all suggest? As i should have bought the duel 4ohms but i didnt i have the duel 2ohms also and need a good amp. My cars electrical system is stock and its in a 2002 dodge stratus running an alpine headunit and 4 gauge wire. Hey tony i was thinking of this amp the Bd1000 from rockford fosgate http://www.bestbuy.com/site/olspage.jsp?skuId=8265548&st=rockford+fosgate&lp=9&t ype=product&cp=1&id=1170289779572 I am sure the guys will comment on that amp for us. If not the bd what about this one. http://www.sonicelectronix.com/item_12211_Hifonics+BXi+1608D.html and also I wouldnt be paying 600 dollars for the fosgate. Hope this helps us both tony. Justin |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 2090 Registered: Mar-06
| Posted on Tuesday, June 24, 2008 - 12:08 am: |
Just grab a better amp. The Kicker ZX1000 would be best for both you guys. Kevin |
Post Number: 93 Registered: Dec-05
| Posted on Tuesday, June 24, 2008 - 12:19 am: |
better than the Rockford fosgate? |
Post Number: 94 Registered: Dec-05
| Posted on Tuesday, June 24, 2008 - 12:23 am: |
O man that is a nice amp. but it costs waaaaaay to much. I can get that bd1000 for 280. brand new. |
Post Number: 95 Registered: Dec-05
| Posted on Tuesday, June 24, 2008 - 01:00 am: |
Hey kevin ok i found that amp for 309 on ebay shipped now do you think its a good amp honestly because i dont want to be buying another amp anytime soon and the amp off ebay is from a store and is brand new. |
Post Number: 96 Registered: Dec-05
| Posted on Tuesday, June 24, 2008 - 02:33 am: |
Kevin? |
TC,
MI
Post Number: 808 Registered: Nov-07
| Posted on Tuesday, June 24, 2008 - 03:27 pm: |
the zx1000.1 and the rockford t1000bd are both great amps you cannot go wrong with either you could probably pick up the kicker for a better price though |
Post Number: 97 Registered: Dec-05
| Posted on Tuesday, June 24, 2008 - 05:32 pm: |
Hey Daniel if it were you and i could get the kicker for 309 dollars as oppose to the 309 that the fosgate would end up costing around the same. but do you think that purchasing the fosgate from a more reputable place as oppose to the kenwood which is online and ebay for that matter? even if they say on ebay that i will get a 3 year warranty |
Post Number: 98 Registered: Dec-05
| Posted on Wednesday, June 25, 2008 - 05:39 am: |
So no one can help? |
Bronze Member Username: Mario_silva
COATZACOALCOS,
VERACRUZ
MEXICO
Post Number: 24 Registered: Jun-08
| Posted on Wednesday, June 25, 2008 - 01:30 pm: |
I do think it is about quality not warranty, i mean quality = perform best and last longer. my personal point of view is that mostly of times we need several opinions about certain stuf to get confidence to it, so maybe you need to take a look on amplifier reviews, that worked for me... |
Silver Member Username: Qslimms
Swanton,
Oh
Usa
Post Number: 120 Registered: Mar-06
| Posted on Wednesday, June 25, 2008 - 01:52 pm: |
i have heard those hifonics are overrated a bit |
Silver Member Username: Snowball123
West Allis,
WI
United States
Post Number: 907 Registered: Oct-07
| Posted on Wednesday, June 25, 2008 - 03:13 pm: |
and it depends if your subs are dual 4 ohm and dual 2 ohm. 2 dual 2 ohm subs you would need a 2 ohm load but with 2 dual 4 ohm subs you would need an amp that is 1 ohm stable. |
Post Number: 99 Registered: Dec-05
| Posted on Wednesday, June 25, 2008 - 04:33 pm: |
ok guys thanks well i have duel 2 ohms subs so they can only be wired down to 2ohms together. so it is between the kicker and the rockford fosgate. any thoughts on which one? |
COATZACOALCOS,
VERACRUZ
MEXICO
Post Number: 25 Registered: Jun-08
| Posted on Wednesday, June 25, 2008 - 04:57 pm: |
how about the Alpine PDX-1.1000 gives you 1000 wrms at 4 and 2 ohm loads, very compact size and it is same brand as your subs... good combo. check it out http://cgi.ebay.com/ALPINE-PDX-1-1000-2008-MONO-AMPLIFIER-NEW-W-WARRANTY_W0QQite mZ180257339478QQihZ008QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
West Allis,
WI
United States
Post Number: 908 Registered: Oct-07
| Posted on Wednesday, June 25, 2008 - 05:24 pm: |
the pdx is a very good amp, but pretty expensive. and i would say get the kicker. |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1746 Registered: May-07
| Posted on Wednesday, June 25, 2008 - 08:27 pm: |
x2 on the kicker. |
Gold Member Username: Drant19
DUB-C,
TX
Post Number: 1081 Registered: Aug-07
| Posted on Wednesday, June 25, 2008 - 10:34 pm: |
as far as the kicker vs. RF amp, there wont be an audible difference between the 2 as far as amps go. the kicker will produce around 1100-1200 and the RF will probably put out 1200-1400. i say save yourself a few bucks n get the kicker. |
Post Number: 100 Registered: Dec-05
| Posted on Wednesday, June 25, 2008 - 11:38 pm: |
Hey abarca i hear you on getting the kicker for the lower price but dont they sale that alpine at bestbuy? because if they do i can get it for less than its listed price. |
DUB-C,
TX
Post Number: 1082 Registered: Aug-07
| Posted on Thursday, June 26, 2008 - 01:40 am: |
check ebay for the kicker amp, u might be able to get a refurb which is pretty much a brand new amp. you can get that kicker amp cheaper than you would be able to get the alpine. |
Silver Member Username: Curious
Post Number: 101 Registered: Dec-05
| Posted on Thursday, June 26, 2008 - 06:51 am: |
ok i found a referb kicker amp on ebay only thing is the warranty on it is only 90 days i found another one for 309 and it is brand new not a refurb with a 3 year warranty both are from ebay. what would you do? Now with the kicker i have noticed that some have red strips on the top running horizontally and the others are missing these red strips does that constitute which one is a refurb and which one is not? |
Illinois
United States
Post Number: 1748 Registered: May-07
| Posted on Thursday, June 26, 2008 - 12:32 pm: |
Got links? |
Post Number: 102 Registered: Dec-05
| Posted on Thursday, June 26, 2008 - 02:18 pm: |
yeah here they are. THis link shows an ebay seller claiming that theres is not refurbished and is new as you can see there are not any red lines. http://cgi.ebay.com/NEW-KICKER-08ZX1000-1-AMPLIFIER-CAR-AUDIO-AMP-ZX1000-1_W0QQi temZ120274929483QQcmdZViewItem?hash=item120274929483&_trkparms=72%3A134%7C39%3A1 %7C65%3A12&_trksid=p3286.c0.m14 THis version is of a seller on ebay that is saying that their amp is refurbished to factory specs....look closely and you will see two red lines running parallel with one another along the length of the amp http://cgi.ebay.com/KICKER-ZX1000-1-CLASS-D-SUBWOOFER-AMPLIFIER-06zx1000-1_W0QQi temZ180257376991QQcmdZViewItem?hash=item180257376991&_trkparms=72%3A134%7C39%3A1 %7C65%3A12&_trksid=p3286.c0.m14 ok and here is a link to a picture from an internet store supposedly new. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19614 notice there are not any lines in their picture... Now i dont know if this is me being picky but i think that this could be a identifier. second i also looked on ebay and some sellers advertise the amp with red lines as new. but they could be lying and selling refurbs as new. what are you alls thoughts. |
Illinois
United States
Post Number: 1761 Registered: May-07
| Posted on Friday, June 27, 2008 - 09:34 am: |
The ones with the red stripes are the 06' models, the ones without are the 08' models. Both are great amps. If you buy on ebay, don't buy from HiFiSoundConnection, many people from here have had issues from them (at least I think it was them?) |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7825 Registered: Jul-06
| Posted on Friday, June 27, 2008 - 11:30 am: |
No, hifi a good store. Indoaudio is the bad one. |
Post Number: 103 Registered: Dec-05
| Posted on Friday, June 27, 2008 - 12:10 pm: |
ahh ok interesting so if i purchase the 08 model is thier any improvements over the other one? thanks guys you all have been a great help |
Illinois
United States
Post Number: 1765 Registered: May-07
| Posted on Friday, June 27, 2008 - 04:16 pm: |
Good to know M.S. If there is any difference between the 2 amps it's not major (from what I've heard). |
Post Number: 104 Registered: Dec-05
| Posted on Friday, June 27, 2008 - 04:31 pm: |
ahh ok well we will see I may purchase the refurb and save a fifty bucks we will see. |
Bronze Member Username: Neptune07
Grand Junction/Golden,
CO
Post Number: 33 Registered: Jun-08
| Posted on Tuesday, July 01, 2008 - 11:56 am: |
hifonics might be slightly overrated but i'm running a 1206d to my two alpine type r 12s and the sh!t pounds. i've been running the amp for 2 years averaging atLEAST 45 minutes of play everyday and its held up nice |
Post Number: 105 Registered: Dec-05
| Posted on Saturday, July 12, 2008 - 10:50 pm: |
Hey boom3r what ohms are your subs rated at ? |
