Thread: Suggestions.. m.s etc |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5370 Registered: Dec-05
| Posted on Tuesday, June 17, 2008 - 09:38 am: |
Hi guys, the subject for today is cheap power.. i need 200w rmsx2 at 4 ohms, (4 channel bridged), right now the one is winning is a profile 1040.. does around 225wrmsx2... any other amp for the money, that's the range of power i need. The cheaper the better, don't like buying High end brands LOL! yeah xD |
Post Number: 5371 Registered: Dec-05
| Posted on Tuesday, June 17, 2008 - 10:22 pm: |
:S |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 4063 Registered: Mar-06
| Posted on Tuesday, June 17, 2008 - 10:30 pm: |
new or used? |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1588 Registered: Mar-04
| Posted on Tuesday, June 17, 2008 - 10:50 pm: |
good idea with the Profile, but I would bet against it actually doing 225 x 2. I would expect more like 175-200, but still quite a bit of power for $100. There's a CEA06 compliant Jensen at sonicelectronix.com for $99 + shipping. Should be a good 250x2 bridged. Looks like a great deal. |
Boston South,
MA
Post Number: 4064 Registered: Mar-06
| Posted on Tuesday, June 17, 2008 - 11:32 pm: |
http://www.millionbuy.com/pericbm771.html http://www.millionbuy.com/phgv752.html http://www.millionbuy.com/kolph4800.html Also check ebay. |
Post Number: 5372 Registered: Dec-05
| Posted on Wednesday, June 18, 2008 - 12:05 am: |
well.. i just need to push some PG RSD components.. so i think that's quite enough. Opti i'd love to buy the heritage 434 but it's out of my range haha |
Post Number: 5373 Registered: Dec-05
| Posted on Wednesday, June 18, 2008 - 12:11 am: |
marc i can speak for kole audio, those 4 channel amps do the work, i bought one for a friend pushing 4 6.5 and it works perfectly, no problems and it's still working after a year. i think i'll go with profile or that PG, really liked the looks on that line |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7738 Registered: Jul-06
| Posted on Wednesday, June 18, 2008 - 11:43 am: |
Yikes is this a battle of the crappy amps or something, lol. IMO the only decent brand mentioned here is PG so I would go with that one. |
Post Number: 5375 Registered: Dec-05
| Posted on Wednesday, June 18, 2008 - 12:29 pm: |
haha crappy amps always rule, you just need to know which ones maintains some quality and their ratings. I'll go with profile, best bang for the buck and bullet proof. |
Northwest PA
Post Number: 7743 Registered: Jul-06
| Posted on Wednesday, June 18, 2008 - 03:01 pm: |
Bullet proof???? Hardly, those amps are well known for overheating. |
Gold Member Username: 420alldaylong
Post Number: 3693 Registered: Sep-06
| Posted on Wednesday, June 18, 2008 - 03:21 pm: |
http://www.onlinecarstereo.com/CarAudio/CompareItems.aspx?CompareItems=18147,181 48 Spec at AutoTek.com |
Lawrence,
Ks
Post Number: 1591 Registered: Mar-04
| Posted on Thursday, June 19, 2008 - 10:07 am: |
I still like that Jensen. <$120 shipped, CEA2006 Certified for 468w, and a 1 yr mfg warranty. http://www.sonicelectronix.com/item_11747_Jensen+Power+Plus+1304.html Could be the new Profile. I've always considered Jensen and Profile to be about equals anyway. |
Post Number: 5378 Registered: Dec-05
| Posted on Thursday, June 19, 2008 - 10:34 pm: |
in numbers, the jensen looks superior IMO.. but.. IDK opti.. i've seen the profile, we've wired it at 1 ohm and it went to protection once, it behaved very well and still working... ihaven't messed with jensen and that's why i'm still vouching for profile. i just need a lil push to buy that jensen haha can you persuade me? LOL! |
Lawrence,
Ks
Post Number: 1594 Registered: Mar-04
| Posted on Thursday, June 26, 2008 - 02:04 am: |
Can I persuade you? Doubtful. I owned one Jensen amp in HS (15 yrs ago). It was some POS 25x2 or something like that, but I paid next to nothing for it and it worked fine. I just think any budget amp that gets CEA2006 certification has a big advantage over the competion since it's basically a guessing game as far as actual power on just about every low cost amp. |
Gold Member Username: Insearchofbass
Post Number: 9762 Registered: Jun-04
| Posted on Tuesday, July 01, 2008 - 04:09 pm: |
The phoenix gold v 752 puts out 75 watts rms x 2 at 4 ohms http://carjamz.com/zen/index.php?main_page=product_info&products_id=2062 # Ryval Series 2-Channel Class AB Car Amplifier # Max power output: 500 watts x 1 chan. # LED power and protection indicators # Remote Monitoring Display (RMD) Port # 2/1 channel operation # Speaker-level input # Preamp RCA outputs # Extruded aluminum heat sink # 3 Position crossover configuration switch # Switchable high-pass filter (100 Hz, 12 dB/octave) # Variable low-pass filter (40-400 Hz, 12 dB/octave) # Frequency response: 20-20000 Hz # Efficiency: 100 dB # Dimensions: 7.90" L x 9.30" W x 2.25" H # 8-gauge power and ground leads recommended # Amplifier Class AB # Number of Channels 2 # RMS Power (4 ohms) 75 watts x 2 channels # RMS Power (2 ohms) 120 watts x 2 channels # RMS Power (1 ohm) N/A # Bridged RMS Power 250 watts x 1 channel # Peak Power Output 500 watts x 1 channel # Minimum Impedance Unbridged 2 ohms # Minimum Impedance Bridged 4 ohms # THD at Rated RMS Power 1% # Speaker Level Inputs Yes # Amp Preamp Outputs Yes - 1 pair # Built-in Crossover High-pass (HP), Low-pass (LP) # High-Pass Crossover Frequency 100 Hz # Low-Pass Crossover Frequency 40 - 400 Hz # Subsonic Filter N/A # Signal-to-Noise Ratio 100 dB # Channel Separation N/A # Bass Boost N/A # Bass/Gain Remote No # Fan Cooled No # Fuse Rating 35A x 1 and the Profile AP600 is supposed to be 100 per channel and has a higher fuse rating but is it as efficient as it claims and the signal to noise is supposed to be better and if thats true thats good....M.S. is right the profile amps do tend to run hot I owned one way back and my cousin owned one from the more recent years and they both ran on the hot side when run for a while in bridged mode....im not sure how they do in stereo but you could ask Yanks Fan if his gets hot because he owns a profile amp that he is using to run his components RMS Power Output (Watts x Channels) 100 x 2 Peak Power Output (Watts x Channels) 200 x 2 Power at 2 Ohms (Watts x Channels) 150 x 2 Bridged Power (Watts x Channels) 300 x 1 Minimum Impedance Bridged 4 Minimum Impedance Unbridged 2 Frequency Response at Rated RMS Power 20-30k Hz THD at Rated RMS Power 0.05% Signal to Noise Ratio 103 dB Input Voltage 14.4v Features Amplifier Class AB Low-Pass Crossover Frequency 50-250 Hz Low-Pass Slope (dB/octave) 12 dB High-Pass Crossover Frequency 80-1200 Hz High-Pass Slope (dB/octave) 12 dB Bass Boost 0-12 dB Bass Boost Frequency 45 Hz Fan Cooled No Fuse Rating 20 x 2 Speaker Level Inputs Yes Preamp Outputs 1 pair LED Power Indicator Green Width (inches) 10-11/16 Height (inches) 2 Depth (inches) 10-5/16 I used to run old an school 100 x 2 Jensen amp bridged and that got very hot so again in stereo mode it might do somewhat better but that amp got too hot so unless Jensen improved alot id be cautious of that brand too |
Post Number: 5388 Registered: Dec-05
| Posted on Tuesday, July 01, 2008 - 05:41 pm: |
thanks sean, i'd like to talk with yanks fan, he used to post in here but now i thik he only goes to subs section. The profile i'm looking at is 1040, i'll run it bridged cuz i need output at 4 ohms. If you reach yanks fan tell him to post i'll try to contact him too. |
Post Number: 9768 Registered: Jun-04
| Posted on Tuesday, July 01, 2008 - 05:44 pm: |
yw....if I reach him before you do ill tell him |
Gold Member Username: Nyyfan13
15 Mag
Post Number: 9975 Registered: Jul-06
| Posted on Tuesday, July 01, 2008 - 11:12 pm: |
Thanks for the link Sean. Julio, I've been running a Profile AP600 for my components for the past year and a few months. Thus far, I have had absolutely zero problems with it. Never cut off, never into protect mode, nothing. Only thing I've experienced that I have some concern for is the fact that sometimes after driving with my system turned up for a while, it will be relatively hot to the touch. But with that said, it doesn't help that I have my box sitting about an inch away from it so it doesn't have much air circulation for it. It isn't the best amp in the world by any stretch of the imagination but it gets the job done at a cheap price. For people on a budget or not much available to them, I would suggest them. I'll be happy to answer any questions you have about it. |
Northwest PA
Post Number: 7849 Registered: Jul-06
| Posted on Wednesday, July 02, 2008 - 08:27 am: |
Hot to the touch is normal, but the profiles are known to overheat to the point of thermal protection. |
Post Number: 9781 Registered: Jun-04
| Posted on Wednesday, July 02, 2008 - 10:47 am: |
no problem Yanks Fan |
Post Number: 5390 Registered: Dec-05
| Posted on Thursday, July 03, 2008 - 02:01 am: |
thanks yanks fan... that's the concept i have of profile... the model i'll buy it's going to run cooler due to the fact that i only need 70w rms of 200w that puts per channel so i think that's a plus. on extreme cases...i might run external fans. I'll tell you how it goes and sean thanks for your time. |
Post Number: 9805 Registered: Jun-04
| Posted on Thursday, July 03, 2008 - 08:30 am: |
your welcome |
15 Mag
Post Number: 9983 Registered: Jul-06
| Posted on Friday, July 04, 2008 - 05:07 pm: |
Anytime Julio. Let me know what happens bud. |
