Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Hey guys need some help here.
Author Thread: Hey guys need some help here.
Username: I0s
Looking to get a nice sql sound..leaning more towards the sq side.
Just want to be able to turn it up sometimes for fun.
Just wondering if someone could help me out with an amp that would work with the following:
Fi Q 15" w/ BP Power (Not sure whether to get dual 1 or dual 2 ohm)
Alpine CDA-9886 HU
Budget: Somewhere around 200-300 but could go a little higher if need be.
Thanks in advance.
Username: I0s
Bump.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5364
RD audio or sundown, PM kevin holden
Username: I0s
Thanks a lot for the info.
Any other ideas?
Or Specific models within these brands?
Username: 420alldaylong
Post Number: 3682
AudioQue.com
AQ1200D $249 1200x1
If you go with this amp get the Fi Q dual 2ohm and wire it to a 1ohm load like in the diagram below.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22
Username: I0s
What is the difference between 2ohm and 1ohm.
And why would you recommend 2?
Post Number: 3685
Its for wiring purpos.
Dual 1ohm sub can be wired to.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=12
Dual 2ohm sub can be wired to.
The reason I said dual 2ohm is because the AQ1200D is 1ohm stable.
Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > Hey guys need some help here. [ « Previous ] [ Next » ]
