Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Powering a 3000watt sub at 1ohm, help...
Author Thread: Powering a 3000watt sub at 1ohm, help plz!
Username: Esprit
I have this sub:
Audiobahn 1208Q 12” Subwoofer
12" 1500 WATTS RMS POWER, 3000 watts max
DUAL 2 OHM VOICE COIL NE
1/4 OHM OPERATION
Should I power it at 1ohm or 4ohm? Id rather just buy a monoblock amp to power it at 1ohm. Is this a good idea?
What WATTAGE do I need from a monoblock amp? Specs on amps dont list what RMS power is at 1ohm, so Im confused.
For example, would this amp power it:
http://www.bossaudio.com/main/817
Username: Neptune07
Grand Junction/Golden, CO
Post Number: 29
DO NOT BY BOSS.
they are cheap and don't put out near what they are rated at.
what is your price range?
you can wire it down to 1ohm on a mono amp but don't get an amp rated over 1500w rms @ 1ohm cause audiobahn subs are known to FRY
Username: Exige
CDT, Audiopulse Dealer
Post Number: 468
Something such as an Audioque AQ1200D would work. I would suggest finding a better sub though. To be very frank, that Audiobahn sounds like complete crap compared to anything else on the market. All you're purchasing is a fake chrome f@rt machine. If you would like some suggestions of where to go for a QUALITY subwoofer, let me know and I'd be happy to help.
Username: Neptune07
Post Number: 43
ya audiobahn makes flashy looking overpriced pieces of cr@p
sell it and find a better quality sub
Username: Esprit
Post Number: 11
Anyone got suggestions for a new sub? I have a 1200watt amp running at 1ohm. Thats how Id like to keep it.
I blew my audiobahn. You guys were 100% right
Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Powering a 3000watt sub at 1ohm, help... [ « Previous ] [ Next » ]
