Thread: Powering a 3000watt sub at 1ohm, help plz! |
New member Username: Esprit
Post Number: 1 Registered: Jun-08
| Posted on Sunday, June 15, 2008 - 07:27 pm: |
I have this sub: Audiobahn 1208Q 12” Subwoofer 12" 1500 WATTS RMS POWER, 3000 watts max DUAL 2 OHM VOICE COIL NE 1/4 OHM OPERATION Should I power it at 1ohm or 4ohm? Id rather just buy a monoblock amp to power it at 1ohm. Is this a good idea? What WATTAGE do I need from a monoblock amp? Specs on amps dont list what RMS power is at 1ohm, so Im confused. For example, would this amp power it: http://www.bossaudio.com/main/817 |
Gold Member Username: Ctmike
Ct.
Post Number: 6281 Registered: Feb-06
| Posted on Sunday, June 15, 2008 - 07:32 pm: |
that sub is only 1500w, you go off of the rms, never the 'peak' or 'max' ratings. and it'd be cheapest to run it at 1ohm. and yes you'll be best running a mono, and without clicking the link i'll say pass on the amp as i can see it's for boss. post a budget. and i'll say it again, imo go with a sundown saz1500d. on sale right now at www.soundsolutionsaudio.com for only $425 shipped. that is if it's within your budget (which you should post for better recommendations). |
Post Number: 3 Registered: Jun-08
| Posted on Sunday, June 15, 2008 - 08:36 pm: |
Thanks, that helps Why are boss amps no good? I owned one years ago and never had a problem with it |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 2055 Registered: Mar-06
| Posted on Sunday, June 15, 2008 - 11:05 pm: |
Boss actually wasnt horrible back in the day, but now along with many other companies, were bought out and built like crap. IMO. The sundown 1500d would kill that sub honestly. I would go with a good 1000d. Save you money and keep your sub running alot longer. Are you running this sub in a audiobahn box as well? I can help you with sundown or rd products. Shoot me an email if you will and I will see what I can do for you on a 1500d or 1000d. kevin lowhz01@yahoo.com |
Gold Member Username: 420alldaylong
Post Number: 3672 Registered: Sep-06
| Posted on Monday, June 16, 2008 - 12:18 am: |
AudioQue AQ1200D $249 1200RMS x 1 at 1ohm AudioQue.com |
Post Number: 4 Registered: Jun-08
| Posted on Monday, June 16, 2008 - 12:47 pm: |
Thanks. All this is helpful. Kevin, and others, why would I power this sub at LESS than 1500 watts rms? What do you mean it would kill the sub? I heard that underpowering a sub is dangerous. Underpowering it 300-500watts less RMS seems dangerous |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1585 Registered: Mar-04
| Posted on Monday, June 16, 2008 - 02:17 pm: |
underpowering a speaker isn't dangerous. As long as the amp's gain is set correctly - the least amount of power to get the desired output is always the best way to go. Underpowering damaging speakers is a myth the uninformed continue to perpetuate. People are recommending 1000w amps because audiobahn subs are notorious for being damaged with rated power. Besides - going from 1000w to 1500w isn't a huge audible difference, but it is a large thermal difference. The trade off of output (minimal) vs the increased likelyhood of damage (significant) isn't worth the cost. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5365 Registered: Dec-05
| Posted on Monday, June 16, 2008 - 11:32 pm: |
i think if you sell that sub you could grab a good pair. |
Silver Member Username: Hittin1
Lake Charles,
La.
United States
Post Number: 474 Registered: May-07
| Posted on Sunday, June 22, 2008 - 01:48 pm: |
AQ1200.. great underrated amp. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7784 Registered: Jul-06
| Posted on Sunday, June 22, 2008 - 04:23 pm: |
Hahahaha if under powering was dangerous your sub would blow every time you turned the volume down |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 17152 Registered: Jun-06
| Posted on Sunday, June 22, 2008 - 06:05 pm: |
"I heard that underpowering a sub is dangerous. Underpowering it 300-500watts less RMS seems dangerous" Opti and M.S. hit it on the head. Lower power tends to push ppl into maxing out the amps settings to compensate for lack of output. Doing that causes distortion and clipped signals and THAT damages the sub. Even at 50% power a distorted signal can fubar a sub. |
Lake Charles,
La.
United States
Post Number: 477 Registered: May-07
| Posted on Sunday, June 22, 2008 - 11:08 pm: |
have you eer heard an AQ1200? Well I dont think that but a select few Might have any bad thing to say about that amp... It is one of the best deal s anywhere for the quality and power.. .AudioQue.com FTMFW!!! If you really wanted to improve the systen you would sell your subs and get a great solid Sub or two that will outpreform those Audiobahn then build a box for them to specs.... You will thank us l8r.. I promise.... good luck bro Do it right the 1st time ad save time and $$$ . Learn from some of our mistakes...Including me! |
Post Number: 5 Registered: Jun-08
| Posted on Monday, June 23, 2008 - 05:24 pm: |
Thanks everyone |
