Thread: No sound from speakers |
New member Username: Fox23
Hanover,
NH
Post Number: 1 Registered: Jun-08
| Posted on Friday, June 13, 2008 - 04:26 pm: |
Swapped out cd/stereo in jeep but blew a fuse in the process. Replaced fuse but now have no sound from speakers. Everything else works. Did I fry something else? |
Silver Member Username: Kaerfpl
Spencerport,
NY
Post Number: 921 Registered: Jun-06
| Posted on Sunday, June 15, 2008 - 04:23 am: |
Check for a Factory Amp |
Hanover,
NH
Post Number: 2 Registered: Jun-08
| Posted on Monday, June 16, 2008 - 10:37 am: |
Thanks for response. I didn't have another power wire hooked up. Apparently it is described as "P. cont". They are working fine now. By factory amp, do you mean there is something else installed here somewhere I'm not aware of? Can they be small and where are they usually stored? |
