Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > 4 Door SUV | two sets of components o...
Author Thread: 4 Door SUV | two sets of components or 1 set + midbass
Username: Invictuz
Seattle, Wa
Usa
Post Number: 207
I quit playing WoW and have decided to get back into car audio so i have a question:
Vehicle - 4 door SUV
Would you go with 2 sets of 2-way components
or
1 set of components in front door and 1 pair of midbass in back doors?
Looking at either 2 sets of CDT ES 620s
or
1 set of CDT ES 620 and 1 pair of CDT ES6 midbass
(both solutions will be sharing an Audiocontrol 6xs xover)
this is me before my eCrack attack: http://www.cardomain.com/ride/784031
The vehicle for my new mobile audio adventure will likely be and 05 tahoe
Username: Hairbandlover
Post Number: 10
I wouldnt get 2 sets of comps I would stick with a good coaxial I went with midbass in my rav 4 and was disapointed.
HU- Alpine CDA-9831
Sub-RE Audio-SR12”
Amps- Alpine MRV-F450 & MRD-M301
Speakers- CDT CL-62, 2 way comp. & CL-6 Midrange
Vehicle- 2004 Toyota Rav 4
Username: Drant19
DUB-C, TX
Post Number: 1064
do not get coaxile speakers, and dont worry about putting speakers in the rear. you dont hear them.
whats your budget for speakers? are you going to run them off the headunit or are you planning on buying an amp to run them?
Post Number: 11
Abarca, did you even bother to ask if he plans on having passangers in the rear?? You are right if he does not need rear speakers if there wont ever be passangers back there but... if there is they suffer especially if the sub or subs are in the back the passangers do not hear any highs at all my system sounds like crap in the back seats because of the " do not get coaxile speakers, and dont worry about putting speakers in the rear. you dont hear them." Just something to think about.
Username: Invictuz
Seattle, Wa
Usa
Post Number: 209
all good input!
I have been entertaining the idea of a midbass in the rear doors and a tweeter set in either the front dash or rear pillar...gonna start a different thread for the tweeter question tho...thanks for replies here.
Username: Alteraudiousa
Concord
Post Number: 1627
hey heck your PM's I sent you one. But as long as the rears are a rear fill and not a rearstage you're fine. But why put midbass drivers in the rear, you want midbass up front near you to enhance your frontstage. But Pm me Invictuz.
Username: Invictuz
Seattle, Wa
Usa
Post Number: 210
i will have rear passengers but not often.
My goal is sound quality and a "full" sound (too often i see installs that are all highs and lows with almost no mids).
To this end i am considering the 3 way ES series...and maybe a midbass under the front seats.
i already have all the amps i need (pair of RF301m mono, pair of RF301x 4channel and a pair of Orion 2500d mono).
My head unit is a bit old and may get replaced; alpine 9831
Username: Drant19
DUB-C, TX
Post Number: 1075
chris w,
i only have front speakers in the front and they can be heard from the rear seats OVER my subs, i send them 150x2... set up your front stage right and all will be good.
Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > 4 Door SUV | two sets of components o... [ « Previous ] [ Next » ]
