Thread: Need help getting an amp for 2 12" l7s? |
Silver Member Username: Extremesound1
Coventry,
RI
United states
Post Number: 278 Registered: Mar-06
| Posted on Wednesday, June 11, 2008 - 11:30 pm: |
i orderd 2 12" l7s D4...so i want to get a 1 ohm mono amp...what would be the best amp for them.. budget is 500$ |
Gold Member Username: Drant19
DUB-C,
TX
Post Number: 1051 Registered: Aug-07
| Posted on Thursday, June 12, 2008 - 12:22 am: |
what kind of car do you have? because i wouldnt run too much more than 1200rms on a stock electrical system |
Silver Member Username: Mmaudioconcepts
Post Number: 494 Registered: Jan-07
| Posted on Thursday, June 12, 2008 - 12:55 am: |
get this amp http://cardiscountstereos.com/catalog%20page.asp?Product+%23=NVAM25001 it puts out rated power. great build quality. |
Silver Member Username: Pbplayer05
Carroll,
Iowa
Post Number: 662 Registered: May-07
| Posted on Thursday, June 12, 2008 - 04:38 am: |
i have my md2d forsale hasnt even been used 6 months does 1800+ its $450 cheapest i could find it even on ebay payed around 700 something for it |
Gold Member Username: Ctmike
Ct.
Post Number: 6274 Registered: Feb-06
| Posted on Thursday, June 12, 2008 - 08:23 am: |
sundown saz1500d, $425 shipped. www.soundsolutionsaudio.com |
Bronze Member Username: Evildoughboy08
Toledo,
OH
US and A
Post Number: 30 Registered: Jun-08
| Posted on Thursday, June 12, 2008 - 10:27 am: |
i would say up your budget a hundred bucks, go to sonicelectronix.com and search JL 1000/1 and get the old one. its currently out of stock so they'll probably just send you a new v2 series. thats what they did with mine. |
Toledo,
OH
US and A
Post Number: 31 Registered: Jun-08
| Posted on Thursday, June 12, 2008 - 10:28 am: |
that is IF the JL1000/1 can handle 1 ohm. im not sure if they do. |
Coventry,
RI
United states
Post Number: 279 Registered: Mar-06
| Posted on Thursday, June 12, 2008 - 11:09 am: |
how about the kicker sx1250.1 its like 450 on ebay...i couldnt find the saz1500 on ebay, and i cant get it off the site bc i dont have credit card.....the sx is almost a 100$ cheaper than the md2d...................what do u think? |
Ct.
Post Number: 6276 Registered: Feb-06
| Posted on Thursday, June 12, 2008 - 11:14 am: |
j/w but if you can't use a credit card how you using ebay? if by paypal, you can pay with paypal. go to caraudio.com and pm denim (he co-owns ssa) and ask. if he can't do it, pm sundownz (he's jacob, the owner of sundown) and get with him, guarrantee he'll help you out. and i'd take the sundown over the kicker, will do alot more power, and for cheaper. |
Coventry,
RI
United states
Post Number: 280 Registered: Mar-06
| Posted on Thursday, June 12, 2008 - 11:21 am: |
i do moneyorder like i just did with the l7'S i got......think i could do money order for sundown |
Carroll,
Iowa
Post Number: 664 Registered: May-07
| Posted on Thursday, June 12, 2008 - 03:06 pm: |
still have mine i can go down to 425 or 420 |
Ct.
Post Number: 6277 Registered: Feb-06
| Posted on Thursday, June 12, 2008 - 04:08 pm: |
if you can't buy a new one using mo, then grab justins'^. but like i said, contact one of the people i've told you about in my earlier post and see what they can do. i'm sure you'll be fine with a mo. |
DUB-C,
TX
Post Number: 1055 Registered: Aug-07
| Posted on Thursday, June 12, 2008 - 06:11 pm: |
"i would say up your budget a hundred bucks, go to sonicelectronix.com and search JL 1000/1 and get the old one. its currently out of stock so they'll probably just send you a new v2 series. thats what they did with mine." ^FAIL theres no reason to get a JL amp because 1. it wont put out the power you need and 2. JL is wayyyyyy over priced! |
Gold Member Username: 420alldaylong
Post Number: 3663 Registered: Sep-06
| Posted on Thursday, June 12, 2008 - 06:57 pm: |
AQ2200D $389 Shipped (2200x1 @ 1ohm) Set gain to power you need. www.audioque.com/ |
