Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > Change or no?
Author Thread: Change or no?
Diamond Member
Post Number: 21278
i was thinking of changing my amp to something that has a bit more power.
currently i have a dls A6 which does 1200wrms @ 1ohm. i was thinking of changing it to an amp that does 1750wrms @ 1ohm.
you think there will be big difference?
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2833
It depends on what amp the 1750rms is...
Keep the SQ brohan just add another one if you want more boomy.
Diamond Member
Post Number: 21279
i was just thinkin. i don't think i could part with my dls amp. lol.
i can't add another one jake cause of the space.
St. Louis, MO / ASU
Post Number: 2835
Get a bigger car.
Diamond Member
Post Number: 21281
i love my car though. lol. me and my car been through alot.:-)
i like the current sealed box and all but i gotta admit, big difference in output. except for the songs that get low. i noticed that this sub plays low well on sealed and ported plays well in the upper frequencies which is better for most rock songs.
so i have decided to try out the epicenter with this sub. that will bring some of the upper bass down low so it might be perfect. actually the epic 160 cause it has that cool db meter. lol.
Username: Jtown
Texas
Post Number: 2974
if you wanted two dls amps, and you plan on doing an amp rack, I have some ideas that you may like that would allow that second a6 to fit
Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > Change or no? [ « Previous ] [ Next » ]
