Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > Which subs???
Author Thread: Which subs???
Username: Deadrabit
Post Number: 439
a pair of RE SX 18s
a pair of FI BL 18s
a pair of AQ HD3 18s
that automic 24 inch woofer
room is not a problem. i will be making a wall. powered by an AQ 2200
i want nothing but SPL!
Username: Deadrabit
Post Number: 444
so no one cares....
Username: Gibsonguy
Storrs, CT
Post Number: 164
i would go with a pair of Sx's out of those choices.
Username: Deadrabit
Post Number: 445
pretty much any other sub ill look at to if its better. but i would like some one to tell me why the sub is better. i don't want to buy something just because its what u have.
after tomo i will be without a system... so i am kinda wanting to know fast.. that and an alt
Username: Deadrabit
Post Number: 446
why would u pick that one? what makes it different?
Username: Gibsonguy
Storrs, CT
Post Number: 165
Well if you want nothing but spl it seems like the best choice. Sx's can get real loud. plus that amp would work well with 2 sx's. they could take more power and probably get louder, but that amp will push them atleast nicely.
Username: Drant19
DUB-C, TX
Post Number: 1053
if u want nothing but spl...2 15" L7s
Username: Deadrabit
Post Number: 447
2 15s???? it doesn't have the cone area or is that the square ones?
the sx and the BL are almost the exact same when it comes to specs. but u can get more stuff with the BL.
the AQ i really dont know anything about. i didn't even know they 18s until the other day.
i say nothing but spl but i might go to one or 2 comps.
ill go a tl and show off and pretty much just show off alot. but this is a daily driver also. and i do like to listen to music
i don't have much time for comps cause i work weekends.
i just dont see any difference in the sw and bl. other than the sx is cheaper
Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > Which subs??? [ « Previous ] [ Next » ]
