Thread: NOT SURE WHAT TO USE FOR THE COMP!!! |
Silver Member Username: Ridinspinnas
Windsor,
Ontario
Post Number: 240 Registered: May-06
| Posted on Wednesday, June 11, 2008 - 07:54 am: |
i just bought a 15" kicker l7, its in a custom box a guy made for me, but it doesnt seem that loud compared to my 2 12" rockford hx2's in a ported box, im not sure which i should use for the competition, i have a hifonics 1600 watt amp and a ma audio 1600 watt rms amp, |
Gold Member Username: Insearchofbass
Post Number: 9521 Registered: Jun-04
| Posted on Wednesday, June 11, 2008 - 08:03 am: |
theres so many things I could ask or add here....ok what type of enclosure is this and what are the external measurements |
Windsor,
Ontario
Post Number: 241 Registered: May-06
| Posted on Wednesday, June 11, 2008 - 11:58 am: |
its vented i can get the dimensions later but if i was guessing its 18" height, 20" wide and 26" long, the vent is about 2 inches wide, cant say much more dude, i think im gonna get another custom box, can u give me specs on a new box a big one, because it will be going in an suv next, thanks |
Post Number: 9537 Registered: Jun-04
| Posted on Wednesday, June 11, 2008 - 12:07 pm: |
as far as the suv just try the box you have and see how it does but I need to know how long and wide the port is to figure out the tuning but as of now without the port and sub you have a 4.32 cubic foot box if those are external measurements |
Windsor,
Ontario
Post Number: 242 Registered: May-06
| Posted on Wednesday, June 11, 2008 - 12:22 pm: |
yes external and i am just guessing, the vent goes d@mn near to the back of the box and is the same height as the box almost, and is almost 2 " wide i dont know if that helps at all |
Post Number: 9538 Registered: Jun-04
| Posted on Wednesday, June 11, 2008 - 03:07 pm: |
sorry I cant guess esp. not without the right box dimensions....I need to have more specifics |
Gold Member Username: Tatonka
-[Team Audib...
Post Number: 1821 Registered: Mar-07
| Posted on Wednesday, June 11, 2008 - 03:14 pm: |
"i just bought a 15" kicker l7, its in a custom box a guy made for me, but it doesnt seem that loud compared to my 2 12" rockford hx2's in a ported box" I think it would be really helpful if you told us the voice coil configuration and how you wired it up. |
Diamond Member Username: Bestmankind
Post Number: 21298 Registered: Oct-05
| Posted on Wednesday, June 11, 2008 - 03:16 pm: |
x2 |
Windsor,
Ontario
Post Number: 243 Registered: May-06
| Posted on Wednesday, June 11, 2008 - 03:42 pm: |
dual 2 ohm wired to 2 ohm on the hifonics amp putting out 1100 watts rms @ 2 ohm, the sub is getting plenty of power, and crazy excursion |
Post Number: 21301 Registered: Oct-05
| Posted on Wednesday, June 11, 2008 - 03:44 pm: |
you can't wire a dual 2ohm sub to 2ohm on the amp. its either 4ohms or 1ohm. now if you have it wired at 4ohm then your sub is barely seeing power. |
Post Number: 21302 Registered: Oct-05
| Posted on Wednesday, June 11, 2008 - 03:45 pm: |
also which model hifonics and ma audio amp do you have? |
Windsor,
Ontario
Post Number: 244 Registered: May-06
| Posted on Wednesday, June 11, 2008 - 03:50 pm: |
the hifonics bxi1608d and the ma audio hk1397 the ma audio amp is pretty crazy |
Windsor,
Ontario
Post Number: 245 Registered: May-06
| Posted on Wednesday, June 11, 2008 - 03:51 pm: |
sorry 4 ohm dvc then all i know is he has it wired to 2 ohm |
-[Team Audib...
Post Number: 1822 Registered: Mar-07
| Posted on Wednesday, June 11, 2008 - 04:28 pm: |
What were the Rockford's wired at? |
Windsor,
Ontario
Post Number: 246 Registered: May-06
| Posted on Wednesday, June 11, 2008 - 04:36 pm: |
4 ohm to my ma audio amp which puts out 1600 watts rms @ 4ohm |
Windsor,
Ontario
Post Number: 247 Registered: May-06
| Posted on Wednesday, June 11, 2008 - 06:27 pm: |
i have a solution ill just bring 2 cars to the show, with both systems lol |
Silver Member Username: Dlavante
Tigard,
Or
Post Number: 111 Registered: Feb-07
| Posted on Wednesday, June 11, 2008 - 07:56 pm: |
ok |
-[Team Audib...
Post Number: 1824 Registered: Mar-07
| Posted on Wednesday, June 11, 2008 - 10:03 pm: |
That's why Chris. You had more cone area and more power on the rockfords.... |
