Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > Jake papa
Author Thread: Jake papa
Username: Theweasel
2 12 FI SSD, Colorado
U.S. of A
Post Number: 1151
in that black aviator you recently installed, did it have a third row seat? and if so, how did you remove it?
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2829
Yeah it had the third row seating. You take off the piece that covers the spare tire bolt and there are sets of screws and bolts under that. Its very easy you just need to find the bolts.
Username: Theweasel
U.S. of A
Post Number: 1152
alright thanks a bunch
i never use that thing, it's like a friggin surfboard
Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > Jake papa [ « Previous ] [ Next » ]
