Thread: Suggestions for Loud Sealed Subs |
Gold Member Username: Jkidder
Worlds gunna end,
In
2012
Post Number: 3603 Registered: Nov-05
| Posted on Tuesday, June 10, 2008 - 12:51 pm: |
i have about 5 cubes to work with. i'd love to have 2 15's sealed in my trunk. i only want to run 3 or 4k for daily but i have an atomic 5k so if i need to i'll crank it up. i just like having head room. what 2 15's sealed can sound alright and handle 1500 or 2k each. not against buying used.. the cisco kid |
Silver Member Username: Prozack52
Cincinnati,
2-D615D4 Dia...
Post Number: 360 Registered: Feb-08
| Posted on Tuesday, June 10, 2008 - 01:00 pm: |
2-15" tc sounds revos |
Silver Member Username: Pbplayer05
Carroll,
Iowa
Post Number: 651 Registered: May-07
| Posted on Tuesday, June 10, 2008 - 01:09 pm: |
whats your budget |
Worlds gunna end,
In
2012
Post Number: 3604 Registered: Nov-05
| Posted on Tuesday, June 10, 2008 - 01:12 pm: |
we'll say 600 on subs. not doing revos... |
Worlds gunna end,
In
2012
Post Number: 3605 Registered: Nov-05
we'll say 600 on subs. not doing revos... the cisco kid |
Gold Member Username: Nyyfan13
15 Mag
Post Number: 9848 Registered: Jul-06
| Posted on Tuesday, June 10, 2008 - 01:29 pm: |
Why not do 2 12"s ported? Or do you have a thing for sealed? |
Worlds gunna end,
In
2012
Post Number: 3606 Registered: Nov-05
| Posted on Tuesday, June 10, 2008 - 01:33 pm: |
im debating but i feel the cone area would outweigh the output ported has over sealed... if that makes ense the cisco kid |
Gold Member Username: Mike11202
RE MT 15 VFL 200.1 ,
Sewell, NJ
US
Post Number: 1776 Registered: Nov-06
| Posted on Tuesday, June 10, 2008 - 03:38 pm: |
well if you can squeeze out 6 cubes get 4 of these http://cgi.ebay.com/2-MB-QUART-PWE-352-15-PREMIUM-SUBS-WOOFERS-PWE352-pair_W0QQi temZ170168127486QQihZ007QQcategoryZ18804QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_ trksidZp1638Q2em118Q2el1247 |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7673 Registered: Jul-06
| Posted on Tuesday, June 10, 2008 - 03:41 pm: |
" im debating but i feel the cone area would outweigh the output ported has over sealed... if that makes ense " In theory you would be wrong. Ported is said to add 3 db in theory over sealed, same as doubling cone area (two 15s is not double the cone area of two 12s) |
Sewell, NJ
US
Post Number: 1777 Registered: Nov-06
| Posted on Tuesday, June 10, 2008 - 03:42 pm: |
actually its cheaper on here http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3877 |
Gold Member Username: Frkkevin
Team DLS SuperNatural...
Post Number: 5205 Registered: Nov-05
| Posted on Tuesday, June 10, 2008 - 03:44 pm: |
04/05 XXX 15"s :P |
Gold Member Username: Jakeyplaysbass
St. Louis,
MO / ASU
Post Number: 2826 Registered: Jul-05
| Posted on Tuesday, June 10, 2008 - 03:54 pm: |
Cant think of many for under 600. Maybe the used xxxs but those would be tough to find as well. |
Sewell, NJ
US
Post Number: 1778 Registered: Nov-06
| Posted on Tuesday, June 10, 2008 - 03:59 pm: |
JBL W15GTi's would work well |
Sewell, NJ
US
Post Number: 1779 Registered: Nov-06
| Posted on Tuesday, June 10, 2008 - 04:04 pm: |
Actually I think the loudest would be 4 12" Pioneer Premier TSW3001's http://cgi.ebay.com/PAIR-PIONEER-PREMIER-TS-W3001D2-12-6000W-SUBWOOFERS_W0QQitem Z350066984028QQihZ022QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Worlds gunna end,
In
2012
Post Number: 3608 Registered: Nov-05
| Posted on Tuesday, June 10, 2008 - 04:12 pm: |
can 05 xxx's sound good in 2.5 sealed a piece? the cisco kid |
Post Number: 5206 Registered: Nov-05
| Posted on Tuesday, June 10, 2008 - 04:24 pm: |
yes, i had one running in 1.4cubes before displacement and burped a 142.2dp on a dd m1 :P in the proper size enclosure, two of them on the right power should be good for 147s |
Post Number: 5207 Registered: Nov-05
| Posted on Tuesday, June 10, 2008 - 04:25 pm: |
btw, ive seen them floating around often, might need to fork $700 shipped for a pair tho, even tho you might find a good deal on 1 here and there |
Worlds gunna end,
In
2012
Post Number: 3610 Registered: Nov-05
| Posted on Tuesday, June 10, 2008 - 05:00 pm: |
im debating doing 2 15's sealed or 2 12s ported.... as MS pointed out the ported is theoretically louder but sealed theoretically allows for more power plus the cone area... im going for loudness. mothertruck sound quality..... the cisco kid |
Gold Member Username: Basssquared
Kansas
Post Number: 2160 Registered: Nov-06
| Posted on Tuesday, June 10, 2008 - 05:36 pm: |
yeah i had the same problem i was trying to find a sub stage that would get me the most SPL with only 5 cubes to work with but with me i only had 1500 watts rms so i went with 4 10's they only need 1.25 cubic feet each so it worked perfect at 5 i just need to build my box and i'll let you guys know how they sound |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 4611 Registered: Jan-06
| Posted on Tuesday, June 10, 2008 - 06:19 pm: |
1 TC sounds 5200 with 3cf and 5K on tap. IMHO if you can reach the same output sealed as you could ported I would go sealed, a lot more musical. Polo. |
Silver Member Username: Teamrevolution
ATLANTA,
GA
Post Number: 302 Registered: May-07
| Posted on Tuesday, June 10, 2008 - 06:30 pm: |
I am going to a sealed enclosure for the first time in a decade. I will let you guys know how it goes. Currently have 3 15" alphas ported tuned to 35hz doing high 152's and am switching to 6 sonance 15" sealed in 6 seperate chambers 2.15 total for each. Hoping to stay 152+ but get a flat response and that LOW-LOW bass. If you are going sealed with 5k and 5 cubes you may want to try and fit more subs to get cone area. |
Worlds gunna end,
In
2012
Post Number: 3612 Registered: Nov-05
| Posted on Tuesday, June 10, 2008 - 07:03 pm: |
i wanted to stay away from the single sub setup. polo, if i was going to go single sub again i'd be doing a 15 tc 5200 or 5400. one reason is motor cooling... 2 12s ported might be the better option... |
Worlds gunna end,
In
2012
Post Number: 3613 Registered: Nov-05
| Posted on Tuesday, June 10, 2008 - 07:04 pm: |
the cisco kid |
Gold Member Username: Insearchofbass
Post Number: 9506 Registered: Jun-04
| Posted on Tuesday, June 10, 2008 - 07:10 pm: |
what vehicle is this going in |
Worlds gunna end,
In
2012
Post Number: 3615 Registered: Nov-05
| Posted on Tuesday, June 10, 2008 - 09:24 pm: |
taurus..... the cisco kid |
Post Number: 9515 Registered: Jun-04
| Posted on Tuesday, June 10, 2008 - 10:12 pm: |
ahh you still have it....well my 95 taurus gl has aprox. a 1 cubic foot sealed box with a single 12 sub with a low fs (20 hz) and it hits best in the low 40's but I get the most annoying noises from my back deck and my dome light and thats on 350 watts hitting 127. something db with the sub firing up....im not sure what would happen with two subs sealed because I havent tried my vehicle with two 12's but my seats dont fold down and my back deck flexes (deck noise I mentioned) with one 12 so im betting im loosing a decent amount of spl |
Chicago,
IL
US
Post Number: 4614 Registered: Jan-06
| Posted on Wednesday, June 11, 2008 - 01:38 am: |
Funny, you get young whipper snappers showing up with multiple subs getting dumped on by old men with a single and a whole lot a power... Polo.. |
Post Number: 9520 Registered: Jun-04
| Posted on Wednesday, June 11, 2008 - 07:53 am: |
yeah one sub setups can work very well and from what I can tell you usually are best sticking with two subs tops as far as spl gains per subwoofer go in a general install anyway....im not done with my set up im just testing to see what works....im trying to focus on low frequency loud |
Worlds gunna end,
In
2012
Post Number: 3617 Registered: Nov-05
| Posted on Wednesday, June 11, 2008 - 09:24 am: |
my back deck jumps like someone is pounding it with a hammer over and over. literally 2 inches each way.... polo, ive always had single sub setups in the taurus so i wanted to try dual this time... i get what youre saying and if i find a deal on a 5200/5400 its all mine the cisco kid |
Post Number: 9527 Registered: Jun-04
| Posted on Wednesday, June 11, 2008 - 09:43 am: |
im sure it sounds tons worse then my back deck but for me its that bad that I literally cant stand the sound so im going to have to figure out how to get rid of it....I thought about removing the rear deck speakers but that wont get all the pressure in the cab that the back deck is holding back so ill have to try another approach....the dome light noise has got to go too |
Worlds gunna end,
In
2012
Post Number: 3618 Registered: Nov-05
| Posted on Wednesday, June 11, 2008 - 05:23 pm: |
bump the cisco kid |
Silver Member Username: Dlavante
Tigard,
Or
Post Number: 112 Registered: Feb-07
| Posted on Wednesday, June 11, 2008 - 08:06 pm: |
if you were willing to go down to 2 12's ported do 2 12" hdc3's. dirt cheap and loud |
Tigard,
Or
Post Number: 113 Registered: Feb-07
| Posted on Wednesday, June 11, 2008 - 08:08 pm: |
229 each + $80 shipping which puts you right under $600 |
