Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > Fuses for my amp
Author Thread: Fuses for my amp
Username: Deadrabit
Post Number: 423
i found this
http://cgi.ebay.com/200-AMP-CAR-RADIO-AMPLIFIER-CIRCUIT-BREAKER-FUSE_W0QQitemZ22 0242810491QQihZ012QQcategoryZ32813QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
im ordering an AQ 2200
is there anything wrong with having one of these other than a normal 200 amp fuse?
Username: Snowball123
West Allis, WI
United States
Post Number: 845
whats the point.
Username: Deadrabit
Post Number: 425
other than having a fuse its a breaker so u don't have to replace the fuse if you blow it.
Username: Bonhamd
TC, MI
Post Number: 743
i use one and its alright. i like it over a fuse just for the convenience of pushing a button.
Username: Deadrabit
Post Number: 428
so i am guessing there is not down side to it? u still get just as much power going to the amp right?
A pic is worth
1000 posts!!
Post Number: 17030
There IS a down side to it. A breaker turns the cautious into the careless. You'll get into the habit of just resetting the breaker instead of finding/solving the problem.
Don't be lazy.
Username: Deadrabit
Post Number: 429
if that is the only downside ill order it right now! yay!
A pic is worth
1000 posts!!
Post Number: 17033
Username: Deadrabit
Post Number: 430
well... idk what that means?
A pic is worth
1000 posts!!
Post Number: 17038
It means I'd like to not see you depend on a breaker. When your sh1t trips it's for a reason. If you don't correct the problem and just keep "hitting the button" it will eventually cause more problems, even maybe a fire.
Think of it like a heart attack. If you could just reset a breaker on your heart every time you have a heart attack does that mean everything's ok now??!!
Think long term man. When your system cries for help/fails it means something. Solve it now. It's more expensive later trust me.
Username: Deadrabit
Post Number: 432
ok i just offered money for it. hahahaha.
its better than spending 14 bucks for a fuse if i drop a wire or something. thats the only time i have blown a fuse. when i droped it on a ground or something like that. if i set something up wrong i will fix it
Username: Nd4spd18
Northwest PA
Post Number: 7679
If you're paying $14 for a fuse that thing better be pure platinum hahaha
West Allis, WI
United States
Post Number: 848
yeah theres no way a fuse costs 14 bucks.
Username: Deadrabit
Post Number: 440
well at the car audio store it cost 14 bucks... WAY over priced. but when i did blow it that one time i didn't want to wait to order one. so i drove and spend the 14 bucks...
Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > Fuses for my amp [ « Previous ] [ Next » ]
