Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > BASS BOOST
Author Thread: BASS BOOST
Username: Howtoeatapencil
Post Number: 163
My HU has -12 to +12 dB bass boost centered at 100hz
My amp has 0 to 18 dB bass boost at 45hz
4" coaxial in the front doors
6.5" coaxial in the rear deck
Im currently using capacitors on my coaxials for high pass filters.
I have 3 pairs
100hz
400hz
600hz
i can combined them to make other things, bit those are the base three capacitors i have.
What would u block where? and what would u boost where?
Username: James1115
Use a simple...
Post Number: 10688
I would run your amp BB at 0, your HU BB at 0 and run the 100hz bass blockers on each set of speakers.
Post Number: 164
the bass blockers are passive so they don't block everything below 100 they just kinda numb it
Username: Nd4spd18
Northwest PA
Post Number: 7674
X2 what James said
Username: Safe_cracker
Chicago, IL
US
Post Number: 4610
Didn't your comps come with a crossover? If not I would get some real crossovers, caps are kinda cheezy...Polo.
Username: Somedonniedude
Illinois
United States
Post Number: 1692
If your HU has an adjustable HPF, I would use it and set it @ 80-100hz and forget caps like polo said. (don't know much myself about caps/bass blockers, but just keep it simple).
Post Number: 165
if i turn the bass boost on the amp up a bit will it damage my sub? like 1/4 to 1/3 up?
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2827
Bass boost pretty much is just a distortion knob. I personally never have mine on. Ive seen people use them very low to just get a little more bass but i wouldnt do it.
Chicago, IL
US
Post Number: 4613
Turn it all the way up on both your head unit and amplifier then go ahead and crank it you'll be ok!
Post Number: 166
I saw someone with two kicker comps and a 300 watt kicker amp with their volume on full gain on full and bassboost on full...very loud very ugly sounding very burnt smelling
Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > BASS BOOST [ « Previous ] [ Next » ]
