Thread: Comepletly Unrelated But Troublesome |
Silver Member Username: Audiosaab
Potomac,
MD
Post Number: 178 Registered: Nov-07
| Posted on Monday, June 09, 2008 - 11:02 pm: |
Hi everyone, please id rather not get flamed or yelled at for this but i trust you all for alot of electrical advice. Anyways, i was driving home tonight and switched on my high beams on a dark road. So after i got off the road, i went to switch them off and they refused to turn off all together! i went home, turned off the car, still they persisted and stayed on. i also tried pulling out the fuse and putting it back in but they turned right back on when i did so. What the hell do i do! i removed the fuse for the night so it dosen't kill my battery.... |
Silver Member Username: Deanerjr
Post Number: 102 Registered: Feb-08
| Posted on Monday, June 09, 2008 - 11:07 pm: |
well. as long as you dont smoke any crack at this time. everything should be fine. im positive. just hang in there bud. D: lol. i think berny would be with me on this. D: |
Gold Member Username: Adam_s
Post Number: 1966 Registered: Aug-04
| Posted on Monday, June 09, 2008 - 11:45 pm: |
The switch is probably shot that controls your lights. I had the same problem with my old car but my lights wouldnt turn on at all. |
Potomac,
MD
Post Number: 179 Registered: Nov-07
| Posted on Monday, June 09, 2008 - 11:55 pm: |
alright thanks steinke ill check it out tomorrow morning |
Gold Member Username: Surferdude9371
Im BTL Bumpin
Post Number: 1023 Registered: Mar-07
| Posted on Tuesday, June 10, 2008 - 01:16 am: |
yeah deff sounds like a switch |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1343 Registered: May-07
| Posted on Tuesday, June 10, 2008 - 02:38 pm: |
switches tend to use 2 sets of contacts if you use high beams alot the tesion spring or coper in the switch it's self, wears, as it wears the switxh gets more and more loose. then it will get to a point where the copper will loose tension or spring all together and it will stay stuck in one position. it is rare though but possible. only other thing is that the switch or your wiring has a short where there stuck on but highly unlikly. |
