Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > 15" Kicker L7 and Hifonics 1600rms?
Author Thread: 15" Kicker L7 and Hifonics 1600rms?
Username: Ridinspinnas
Windsor, Ontario
Post Number: 237
I just got a deal on a new kicker l7 15" and a hifonics 1606 i believe or whatever the 1600 watt rms amp, the box is custom but im not sure on the specs as i was in a hurry to get the equipment didnt even talk to the guy really, anyways its going in my expedition its only wired to 2 ohm so putting out around 1600 watts rms i have 0 gauge wire, and all the good stuff, how many decibels do you guys estimate this will hit, this is temporary im getting 3 more and a couple more amps, let me know thanks guys
Username: Audiosaab
Potomac, MD
Post Number: 177
Quick question, the 15" kicker l7? is it a 4ohm or 2ohm? and then on top of this the Hifonics 1606, considering i have one only pushes 1100rms at a 2 ohm rate (which is overrated) but im not sure otherwise...also you probably don't need 0 gauge, 4 gauge would be sufficient enough..
Username: Tatonka
-[Team Audib...
Post Number: 1814
I feel comfortable to guess a 139.6
Username: The_image_dynamic
San Diego, California
Post Number: 4098
139.5 in case Nick went over, then I win.
Username: Tatonka
-[Team Audib...
Post Number: 1815
I did not go over, in fact I R exact. Just do the math brad. The subcon gain vs the precon loss is in a square ratio. It is unheard of to be wrong.
Post Number: 4099
Nick is correct. I failed to factor in the precon loss. My bad.
Username: Tatonka
-[Team Audib...
Post Number: 1816
It's simple geoconatrigpoonoligy, Brad
Username: Deadrabit
Post Number: 420
thatis some very good work on the... um... geocon BS.
ill say 1db in case u guys both go over.
its time for THE DB IS RIGHT!
dude there is no way to tell how loud it will be.
Diamond Member
Post Number: 21255
last year at one show, this guy hits 140 with a 10 inch L7 with 800wrms. his car was a crx.
Windsor, Ontario
Post Number: 238
yeah some guy made me a box for a 100 bucks when i bought the equipment i have no idea on the specs but i have a feeling it is too small, and its wired to 2 ohm at 1100 watts rms,
Windsor, Ontario
Post Number: 239
i also have an amp that can give it 1600 watts rms but i dont know if it would make it ne louder, should i spend the extra money and get a bigger box built?
Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > 15" Kicker L7 and Hifonics 1600rms? [ « Previous ] [ Next » ]
