Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > 2 amps in a series
Author Thread: 2 amps in a series
Username: Evildoughboy08
can i wire 2 amplifiers in a series? what i mean is to send the 4gage batt. to one amp, the ground from that amp to the power on a second amp, and then the ground on that second amp to the chassis. would my unit function correctly?
Username: Snowball123
West Allis, WI
United States
Post Number: 843
that would be a negative. just get a distro. block for the power wire to both amps, then ground each amp like normal.
Username: N2audio
Lawrence, Ks
Post Number: 1586
It will work as long as the 4 ga is sufficient size for both amps, and the other associated wires are large enough.
Basically you're just using the amp terminals as D-blocks.
It can turn ghetto pretty quick though.
Toledo, OH
US and A
Post Number: 50
how could it turn ghetto real quick?
Username: N2audio
Lawrence, Ks
Post Number: 1592
when you have six wires connected to the power stage of an amp...it can get ugly. Especially if you're using big wires. D-blocks aren't expensive. If you want it to look organized that's definitely the way to go.
Toledo, OH
US and A
Post Number: 52
whats the difference between fused and infused Dblocks?
and i have a 4 gauge set, would i need a 4 gauge input and 2 8 gauge outputs on the D-blocks?>
Toledo, OH
US and A
Post Number: 53
oh and where did you get 6 wires from?
im sending one power wire from the battery to my 4 channel, the ground from my 4 channel to the power on my 2 channel, and the ground from my 2 channel to the chassis... i only count 3 wires there..
Home > Message Board > Car Audio > Amplifiers > Archive through July 29, 2008 > 2 amps in a series [ « Previous ] [ Next » ]
