Home > Message Board > Car Audio > Navigation Systems > Bypass Dual XDVDN8290
Author Thread: Bypass Dual XDVDN8290
Username: Bphunk
Does anyone know if this can be bypassed so that you can watch DVD's and use the nav system while driving?
Username: Grnnc
Post Number: 47
Yes,you can connect a toggle switch. My son got his dvd/navigation sys installed at best buys and the tech installed a toggle switch which allows you to watch dvd while driving.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Navigation Systems > Bypass Dual XDVDN8290 [ « Previous ] [ Next » ]
