Thread: Questions / Comments on new build |
Silver Member Username: Nissankicker
Grambling,
LA
Post Number: 289 Registered: Mar-06
| Posted on Monday, June 09, 2008 - 12:19 pm: |
What do you think about: (8) 12" Kicker Comps Sealed * (8) 12" Diesel Audio NSH-12s Sealed * or (10) 12" Kicker Comps Sealed I'm goin' to be putting this is my '99 Nissan Sentra GXE .... ... The questions are: 1) Should I common chamber all? 2) If so, why? 3) Chamber? 4) if so, how many in each chamber? The dimensions of the box is similiar to the SuperBass Ported ProBox for (2) 12" L7s ( 40w x 25d x 14h ) - I can slightly modify... * NOTE!!! This is my " Hood Beat " build! ... Looking to get alot of trunk action, and possibly some good pressure as well. ( 142db + ) - Not really lookin' to compete with this one. |
Diamond Member Username: Bestmankind
Post Number: 21228 Registered: Oct-05
| Posted on Monday, June 09, 2008 - 12:23 pm: |
you gonna need to do more than slight modify to put that maney subs. i don't even know how you gonna fit 8 12inch subs in the trunk of a sentra. but good luck. i haven't heard the diesel audio so i don't know about them but i like the way those keeker subs sound. |
Grambling,
LA
Post Number: 290 Registered: Mar-06
| Posted on Monday, June 09, 2008 - 12:38 pm: |
I fit (6) 12s sealed... I just wanna do something crazy. .... I heard 4 Comps. They sounded pretty good sealed ( Ford Expedition ). |
Post Number: 21231 Registered: Oct-05
| Posted on Monday, June 09, 2008 - 12:40 pm: |
damn man that sentra must have a good size trunk. i want to see pics of this sh!t when you get it done. mad props. anyways yeah like i said i liked the way the kicker sounded. |
