Thread: WTF. help? |
Bronze Member Username: Deanerjr
Post Number: 96 Registered: Feb-08
| Posted on Monday, June 09, 2008 - 11:45 am: |
well yeah. everyone remembers me talkin bout those crappy q powers cuttin out. well my 10" Kicker CVT's never do it. just now i was bumpin the sh*t out of a song. and they just turned off. like stopped hitting and everything. well i figured "hey they probably couldnt take it and went into protect like that sh*tty pair before" well i waited a few minutes and turned the subs on and off from the in dash and they still werent playing. well any idea what happened? or do i just have to wait a lil while before they go outta protect? dunno if its the amp or sub not turnin on. |
Silver Member Username: Prozack52
Cincinnati,
2-D615D4 Dia...
Post Number: 349 Registered: Feb-08
| Posted on Monday, June 09, 2008 - 11:57 am: |
there should be a protect light on your amp see if its on first, then if not check all your connections being you were bumpin the sh$t out of it to make sure nothing jared lose |
Post Number: 97 Registered: Feb-08
| Posted on Monday, June 09, 2008 - 12:01 pm: |
yeah. i dont think its in protect i cant even find the light =\ and the thing is if its in protect, if you turned off the truck for about ten or fifteen minutes and left it there off. wouldnt it be fine again once you started it back up? cause its not =\ |
Post Number: 98 Registered: Feb-08
| Posted on Monday, June 09, 2008 - 03:29 pm: |
yeah, theyre still not cuttin back on. nothing is rattling and the subs dont look like theres anything wrong. they just wont turn back on? |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1677 Registered: May-07
| Posted on Monday, June 09, 2008 - 05:21 pm: |
Is the amp warm or how? |
Post Number: 99 Registered: Feb-08
| Posted on Monday, June 09, 2008 - 10:32 pm: |
amp seems fine, but im about to look for the manual to see if one of the lights that isnt lighting up is the power light. cause the subs look fine, i had a guy from my job say he thinks i may have distorted them, but they wont even turn on right now. |
Gold Member Username: Rideredder
Cornell,
IL
Post Number: 1440 Registered: Sep-05
| Posted on Monday, June 09, 2008 - 10:55 pm: |
Did you check all your fuses? |
Silver Member Username: Deanerjr
Post Number: 101 Registered: Feb-08
| Posted on Monday, June 09, 2008 - 11:00 pm: |
havent yet. plan on it. looking at the manual. i dont think my amp is getting power. theres two little lights, and neither is lit. which leads me to think one is the power and its not getting any? lol. btw, ive got a MTX TC6004. |
Gold Member Username: Adam_s
Post Number: 1967 Registered: Aug-04
| Posted on Monday, June 09, 2008 - 11:48 pm: |
Check the fuse on the power wire from the amp. If thats not blown make sure the amp is grounded good. |
Silver Member Username: Quirky
SA,
Texas
Post Number: 267 Registered: Feb-07
| Posted on Tuesday, June 10, 2008 - 12:52 am: |
ya, if you have a voltage meter on hand go around and check your remote and power wire for current. like steinke said check your ground well meaning no painted surfaces. |
Post Number: 103 Registered: Feb-08
| Posted on Tuesday, June 10, 2008 - 02:39 pm: |
alright ima have someone check it too just in case lol. |
